First REW graphs - Advice pls - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
REW Forum
Discuss First REW graphs - Advice pls in the Subwoofer Equalization | Calibration forum; First REW graphs - Advice pls Hi guys, Posted the first of the graphs over on AVForums, but pointed to the REW forum here for more ...
Old 04-19-07, 12:53 PM   #1 (Link)
Alias: Ninj
User: #7028
Ninj is offline
Hi guys,
Posted the first of the graphs over on AVForums, but pointed to the REW forum here for more advice.
The blue line is the in phase graph, the green is 180 phase. I was reasonably happy with the in phase but needed to sort the dip at 62Hz and the peak at 45Hz.
In an attempt to move the 62Hz dip, I tried inverting the phase which has introduced a more unstable curve, but its moved the deep dip nearer to the 80Hz crossover. The 45Hz peak is stil there, but I think that is a room issue??
I have a BFD sitting here awaiting cables so Im sure I can help iron out those problems, but any advice or suggestions most appreciated.
Thanks in advance
Richie
Old 04-19-07, 01:10 PM   #2 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is online now
Re: First REW graphs - Advice pls
Hi Richie,
What's your crossover point? 60Hz? Are these measurements with the mains on? If so, take measurements again with them off and let's see how that looks.
Both curves look a little rough. Can you play with sub placement and delays? Where's the sub located now?
You should be able to get it looking better than it is now -- one way or another!
-- Otto
Old 04-19-07, 01:13 PM   #3 (Link)
Alias: brucek
User: #6
brucek is offline
You're not getting a lot of extension below 40Hz. What type of subwoofer are you using? Are you using a Radio Shack meter with the calibration file in REW?
You can also use speaker time delay settings to modify the phase between the sub and mains in a smaller increment than would be achieved with a 0deg vs. 180deg change of the phase switch.
otto...quickest draw in the west.. beat me
Old 04-19-07, 01:24 PM   #4 (Link)
Alias: Ninj
User: #7028
Ninj is offline
Hi guys, thanks for the replies.
Yep, using the new cal file for the RS 4050 SPL. The sub is pretty new so could explain why its not going down too low yet. Only has about 20 hours on it tops.
The sub is in a corner (out from the corner by about 4"), although it has a couch on one side. Im kinda stuck with that rough placement for now.
i have the amp crossover set to 80Hz at the moment, although I have adjustment between 40 and 200 Hz. Is it worth moving the crossover?
The sub has a frequency adjustment on it between 0 and 200Hz and although it shipped set to 200, Im not entirely sure what effect it is having. The sub is a Mordaunt Short 309i.
Those graphs are with mains on, Ill try another if I can see how to isolate the mains and just use the sub, if not Ill just unplug them.
Thanks again
Richie
Old 04-19-07, 01:38 PM   #5 (Link)
Alias: Ninj
User: #7028
Ninj is offline
Ok guys this is the sub only. Green = 180, red = in phase.
Youll see theyre virtually identical. Surely something is wrong there? I would have expected them to be completely different??
I think my next step is to adjust the sub distance in the amp menu to try and move the 69Hz dip up nearer to the crossover?
Thanks
Rich
Old 04-19-07, 01:38 PM   #6 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is online now
Hi guys,
I think 80 Hz is OK for now. Be sure the one on the sub itself is set to its max (200 Hz). Setting it to its max will effectively remove that crossover from sub's signal path. You're letting the receiver do the bass management, which is most likely the way to go.
Unfortunately, I doubt you will gain much more low-end extension just by allowing a break in period. If possible, I might move it a little more out of the corner. 4" might be a little tight. I know how it is with placement sometimes, though, so if you can't it's OK.
-- Otto
Old 04-19-07, 01:40 PM   #7 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is online now
Ninj wrote: View Post
Thanks
Rich
Well, without the mians involved, there's no point of reference for any phase difference, so I wouldn't expect much of a difference (you probably know by now, but there were no graphs attached).
Are you running the mains as "large" or "small"?
-- Otto
Old 04-19-07, 01:54 PM   #8 (Link)
Alias: brucek
User: #6
brucek is offline
You'll see they're virtually identical. Surely something is wrong there? I would have expected them to be completely different??
Phase and distance are not perceivable with a single speaker. They are meaningless by themselves.
Old 04-19-07, 01:58 PM   #9 (Link)
Alias: Ninj
User: #7028
Ninj is offline
Otto wrote: View Post
Hi guys,
Thanks Otto, I have the subs freq set to 200, understand how that works now.
Its actually about 6" from the corner, but its a dog leg corner if that makes sense.
Rich
Old 04-19-07, 02:00 PM   #10 (Link)
Alias: Ninj
User: #7028
Ninj is offline
Mains set to small.
Ah I understand that now about phase. So its with reference to the mains. I get it thanks. If I was to plug the mains back in, Id see the difference again.
Rich
ps the graph should be there at post #5?
Old 04-19-07, 02:36 PM   #11 (Link)
Alias: brucek
User: #6
brucek is offline
Did you tell us the model of the sub?
Old 04-19-07, 02:41 PM   #12 (Link)
Alias: Ninj
User: #7028
Ninj is offline
Sure did, its a Mordaunt Short 309i.
link
Old 04-19-07, 03:33 PM   #13 (Link)
Alias: brucek
User: #6
brucek is offline
OK, the response is consistent with the specs of the sub, which is ~-3dB down at 35Hz.
You will have to use a BFD filter or two in the 40Hz to 60Hz range to reduce the peak you have there. That will bring out the lower frequencies much better. You may be able to reduce the mains added effect at 80hz with a sub filter there also, but you'll have to see how that goes...
Old 04-19-07, 03:49 PM   #14 (Link)
Alias: Ninj
User: #7028
Ninj is offline
Thanks Brucek.
Do you think theres any point in using the subs own notch filters?
Thanks again, all help much appreciated
Old 04-19-07, 03:52 PM   #15 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is online now
How are they implemented? i.e., what controls are there? I'll have a look for the manual on the web, time permitting.
-- Otto
Old 04-19-07, 03:57 PM   #16 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is online now
Got it. Looks like a gain and frequency are selectable, bandwidth is not. It might be an interesting experiment to try to address that peak at ~45 Hz. However, since you already have a BFD, you will find that it's much more powerful.
-- Otto
Old 04-19-07, 04:02 PM   #17 (Link)
Alias: Ninj
User: #7028
Ninj is offline
Yeh I suspected the BFD would have the edge. Ill give it a go and report back once Ive put some filters on.
Am I right in thinking, in basic terms, rca from amps low level subwoofer socket to 1/4" jack plug into the BFD. Then 1/4" out from BFD to RCA into the sub?
Just had a quick look at the BFD manual and couldnt find a real easy connection diagram.
Thanks
Rich
Old 04-19-07, 04:06 PM   #18 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is online now
In general, that's right. You'll want to use a mono TS 1/4" plug. There are also adapters available at RS if you're in a hurry. So, that'll inset the BFD into the signa path.
It looks like you've already got REW working, and that's an excellent start!
-- Otto
Old 04-19-07, 04:08 PM   #19 (Link)
Alias: Ninj
User: #7028
Ninj is offline
Thanks
And I assume I can use XLR to rca instead of 1/4"? Are XLR stereo/mono
Old 04-19-07, 04:15 PM   #20 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is online now
The XLR out will be balanced, so you will only use one of the "hot" legs. I'm not sure of the exact orientation of the pins on the XLR, but I'm pretty sure it's available in the various manuals and the web. brucek will probably know more about creating one. While I like the look and feel of the XLR, there's no reason to go away from the 1/4" mono plug. I think it will be easier to deal with in a DIY cable, and will be more readily available at RS, PartsExpress, etc.
-- Otto
Old 04-19-07, 05:27 PM   #21 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
The XLR will be Pin 2 (+), Pin 3 (-), Pin 1 shield. The Pin 2 lead will go to the RCA’s tip, with Pins 3 lead and the shield will be tied together to the RCA’s sleeve. If you’re using single-conductor cable, install a jumper between pins 1&3 at the XLR.
No good reason to use XLRs over 1/4” mono, although some people seem to prefer them.
Old 04-20-07, 01:49 AM   #22 (Link)
Alias: Ninj
User: #7028
Ninj is offline
Thanks,
Ill just stick with the 1/4 to save any confusion.
Rgds
Richie
