| REW Forum computer recommendation for REWDiscuss computer recommendation for REW in the Equalization | Calibration forum; computer recommendation for REW How much computer do you need to run REW?
I'd like to do this once and not buy too little ... |
Views: 508 - Replies: 4
| computer recommendation for REW How much computer do you need to run REW? I'd like to do this once and not buy too little or too much. Any recommendations? If you have a specific computer model number, I'd be interested in that too. Thanks, Jim | ||||
| | #2 | ||||
| Re: computer recommendation for REW I don't think you need much. Getting past the initial setup with the soundcard seems to be the biggest trouble. IIRC, I'm using a Dell E520 and have never had a problem. I've used a SoundBlaster Live! soundcard with MIDI out, as well as a C-Media cheapy soundcard. Both work fine. -- Otto | ||||
| | #3 | ||||
| Re: computer recommendation for REW Otto, Thanks for the response. In checking with ebay, Dell E520s bring up a bunch of desktop computers with 2.8ghz dual core processors. This doesn't sound like your laptop, unless the E520 only refers to the processor. | ||||
| | #4 | ||||
| Re: computer recommendation for REW I went back and checked my "profile" (forgot about that when initially responding). It's an E510, and it's a desktop. 2.8 GHz sounds about right, but I'm not sure if it's got a dual core processor. Here's a -- Otto | ||||
| | #5 | |||||
| Re: computer recommendation for REW Quote:
brucek | |||||
