| REW Forum am i doing something wrong ?Discuss am i doing something wrong ? in the Equalization | Calibration forum; am i doing something wrong ? hi all,
ive been reading about the bfd on this site for a while and even bought a dsp1124p almost ... |
Views: 582 - Replies: 6
| am i doing something wrong ? hi all, ive been reading about the bfd on this site for a while and even bought a dsp1124p almost a year ago. i finally got the time to hook it to a sub and after doing some measurements and sending the filters to the BFD, it didnt make any difference in the graphs. from all other indications the filters are sent and stored in the bfd. the graphs before and after are the same. i can change the sub response by moving it in the room so i know its reading the sub. any ideas ? | ||||
| | #2 | |||||
| Re: am i doing something wrong ? Quote:
Shut the BFD off, then power it back on while holding the Filter Select switch down. While holding the button down the version number will show in the BFD display. If it says 1.3 then you need a new PROM with 1.4 firmware. See this thread. Or you can enter the filters manually [which is quite easy to do and a lot less hassle]. brucek | |||||
| | #3 | ||||
| Re: am i doing something wrong ? thanks brucek, looks like i got one. what a shame too, i used to program & change proms / eproms on a daily basis when i worked as a tech. had a burner and trashed it with all the other "junk". hey at least they used sockets on the proms ! this unit is not for my HT, im tinkering with it for future installs, do the new ones have updated firmware ?? if so i'll buy another onw for now till i get this one upgraded thanks | ||||
| | #4 | |||||
I guess if you're doing installs, you use REW? brucek | |||||
| | #5 | ||||
| Re: am i doing something wrong ? we havent used any software other than the auto setup in the recievers. we use onkyo recievers and various speakers. most of our customers main concern is cosmetics, so we put in alot of inwalls and hidden electronics. what im trying to do is get the best sound for our price range which ranges from 3 to 5k. i did however use REW to check the sub on one job. the room was the hardest ive had to work with. it had a JBL ep250. sounded bad and we had a hard time getting it in a good spot so i brought my pc over there and ran REW. it wasnt good but with the help of REW we got the best we could(no BFD). i dont like that sub but the customer wanted it, so its in there. thanks again, i just checked my account and we bought the BFD in july of 2006 so i guess they will send me a prom | ||||
| | #6 | ||||||
A lot of people here have the receivers with auto eq and seem to like it quite a bit. They always seem to still add a BFD for that low room mode though... brucek | ||||||
| | #7 | |||||
