REW Forum
rew wiring connections
Discuss rew wiring connections in the Equalization | Calibration forum; rew wiring connections A little confused on the wiring-- the more common setup seems to be as posted in the attached jpeg. However, ...
Views: 727 - Replies: 10
Old 04-27-07, 04:17 PM   #1
bwana
Inactive
Alias:
User: #
Posts: n/a
A little confused on the wiring-- the more common setup seems to be as posted in the attached jpeg. However, I have found a few references on the web where the
left channel of the pc output is connected to the left channel of the pc line in. I do not understand why one would want this feedback loop in place. Should it be left disconnected at all times? Tnx.
Old 04-27-07, 05:52 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: rew wiring connections
Yes, except when you are creating the soundcard calibration file, then you use a short between the right channels out and in instead of the regular connections. After that, the file you created compensates for any response imperfections in the soundcard.
Old 04-30-07, 01:09 PM   #3
Alias: chad
User: #7756
Since: Mar 2007
  cburbs is offline
So can you run REW withouth the BFD in the picture to get at least a graph and start of what needs to be fixed?
Old 04-30-07, 01:24 PM   #4
Alias: brucek
User: #6
Yes, certainly.....
Old 04-30-07, 01:30 PM   #5
Alias: chad
User: #7756
Since: Mar 2007
  cburbs is offline
Thanks Brukek - do you think this card in my PC will work- CHAINTECH AV-710?
http://www.short-media.com/img/450
Old 04-30-07, 02:25 PM   #6
Alias: brucek
User: #6
Yep..........
Old 04-30-07, 11:03 PM   #7
Alias: chad
User: #7756
Since: Mar 2007
  cburbs is offline
OK Thanks.
Old 04-30-07, 11:09 PM   #8
Alias: brucek
User: #6
Yes....... do you have a question?
Old 05-06-07, 01:17 PM   #9
Alias: chad
User: #7756
Since: Mar 2007
  cburbs is offline
So going from the PC Sound card to SPL meter I use 1 single rca cable out of the right side to SPL meter?
Going from the line out to reciever I use a y-splitter cable and do I connect right and left Aux on Receiver or just Right on Receiver?
Old 05-06-07, 01:48 PM   #10
Friend of the Shack
Alias: Otto
Otto's Avatar
Loc: Beautiful Colorado
User: #625
  Otto is offline
cburbs wrote: View Post
Well, you're actually going "from" the SPL meter "to" the sound card. But yeah, a single RCA cable is correct, and you can go into either right or left. Most of us use left because REW defaults there, I believe. I doesn't matter which, as long as you know which one you're using, and you specify it that way in REW's "Settings" menu.
I have an analog connection from my PC to my preamp that is in place 24/7, and both left and right are connected. That's how I use it. When you integrate your mains with your sub, you will definitely want them both (L/R in addition to the sub) playing at the same time, so it's best/easiest to use the L/R connection from the sound card to the receiver. REW will output the same signal on R/L (i.e., it's mono).
-- Otto
Old 05-06-07, 01:51 PM   #11
Alias: brucek
User: #6
The PC soundcard line-in and line-out jacks are stereo, but we only want to use one of the two channels. To accomplish this, we use a stereo to two mono adaptor plugged into the line-out and one plugged into the line-in. Then we use the left or right channel and plug the mono SPL meters output into one of the line-in channels and connect one of the line-out channels to the receiver...
Going from the line out to receiver I use a y-splitter cable and do I connect right and left Aux on Receiver or just Right on Receiver?
That's up to you. Some people just use a single channel on their receiver, but others use a Y splitter and plug it into left and right of the receiver....
edit.... oops, queeksdraw beat me to the punch again......
