Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Equalization | Calibration > REW Forum
REW Forum
  Discuss First graph in the Equalization | Calibration forum; First graph Hi guys! I finally came around to getting some measurements done , I'm not really sure of what I'm doing ...
Views: 1284 - Replies: 28
Old 04-28-07, 05:06 PM   #1
Alias: FguerraG
Loc: Victoria,Mx
User: #7537
Since: Mar 2007
  FguerraG is offline
First graph
Hi guys!
I finally came around to getting some measurements done , I'm not really sure of what I'm doing I'm just following the help files as a trained monkey.
anyway this is my graph I have made several of them an I get the same results so I guess this is good , now I need recomendations on getting the correct filters to my BFD
TIA!
BTW:
I'm connected through my AV receiver so my front speakers where measured as well not sure if that is ok...
Old 04-28-07, 05:38 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: First graph
Disconnect the fronts and take a look at the sub alone.
Change the graph axis limits to a vertical scale of 45dB to 105dB and a horizontal scale of 15Hz to 200Hz and repost...
Set the target crossover to the one you're using for a reference to see how the sub looks. i.e. 80Hz
Old 04-28-07, 06:35 PM   #3
Alias: FguerraG
Loc: Victoria,Mx
User: #7537
Since: Mar 2007
  FguerraG is offline
Re: First graph
Is this better?
The axis have been corrected and the cutoff is at 80 which is how I got my crossover set up
Old 04-28-07, 07:05 PM   #4
Alias: brucek
User: #6
  brucek is offline
Re: First graph
I guess the mains are still operating in the above graph, since the sub doesn't show the 80Hz rolloff?
Old 04-28-07, 07:58 PM   #5
Alias: FguerraG
Loc: Victoria,Mx
User: #7537
Since: Mar 2007
  FguerraG is offline
Re: First graph
I don't get it
when you say disconect the speakers , you mean just unhook the speaker cable or should I turn them off at my av receiver
I have been making several measurments and still can't get a 80hz rolloff
Old 04-28-07, 08:09 PM   #6
Alias: brucek
User: #6
  brucek is offline
Re: First graph
If you can shut them off at the receiver, then that's fine as long as they don't play. Put the receiver in stereo and select the mains as small and the crossover at 80Hz and then shut down the mains. Usually, when you have a receiver you have to remove the speaker cables (with the power off of course) to shut the mains off, but some receivers allow it. If you have a separate power amp for the mains, you can simply shut it off...
Old 04-28-07, 09:39 PM   #7
Alias: FguerraG
Loc: Victoria,Mx
User: #7537
Since: Mar 2007
  FguerraG is offline
Re: First graph
Last try for today
receiver is set to stereo crossover @ 80Hz the calibration has been made with REW subwoofer pink tone to 80db in order to maintain my regular listening volume
is this what I'm looking for?? or can some one post a graph of what MY graph should look like
Thanks in advance
Old 04-28-07, 10:18 PM   #8
Shack Moderator
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Re: First graph
That looks more like it. I’d try smoothing your graph to 1/6-octave (or whatever brucek usually recommends – I forget what it is, but I like 1/6 personally). Anyway you can experiment with some different locations? That depression below 30 Hz looks like it’s going to be a real problem.
Old 04-28-07, 10:36 PM   #9
Alias: brucek
User: #6
  brucek is offline
Re: First graph
Well, actually we only use smoothing for full range measurements, where reflections can cause comb filtering that makes it difficult to see the underlying trend of the response. It is rarely used for low frequency measurements as it would obscure the true shape of the response and so not allow accurate correction filters to be determined.
Yep, I wanted to see if the mains were influencing the sub in that dip area around 30Hz, and they're not.
You've got about four peaks that could be equalized and would result in a much smoother result. I'm sure if you use REW to find peaks and then assign filters and play around a bit, you will reveal what the final response would look like if you used a BFD...
Old 04-29-07, 01:28 AM   #10
Alias: MACCA
MACCA350's Avatar
Loc: Australia
User: #149
  MACCA350 is offline
Re: First graph
Something funny going on because your first graph shows you're getting great response all the way down to below 2Hz, unless you have a rotary woofer, there is something funky going on. And with these graphs we cant see where the natural roll off of you sub is, and since you really don't want to boost below what your sub is capable of you need to find out whats going on with the readings.
BTW what sub do you have?
cheers
Bookmark and Share
Dish Network
