With USB to serial adapter, it is possible to 'simulate' rs-232, i.e. Shure workbench, elo touchscreens, etc
could this be possible with REW, to control DCX2496 ?
Yes, it would be possible on Windows using the Java serial comms library (that is how the TMA processors are controlled), but I haven't got around to implementing that for the DCX - partly because I don't have a unit to test with but mostly because other things are taking priority.
Hi John
long time I haven't been here, sorrrrry
I've got REW for WIN ( xp ) and the included java, seems to work great, except I think….
I was smoothing 1/3rd oct. and the lowest filter wouldn't appear in DCX249 filters when optimizing ...
When I smoothed 1/6 oct, it worked…
Shy question,
do you have DCX2496 control via rs232 included now ?
I'll be doing some work with REW tomorrow and will control a DCX2496 via rs232 - if need be with the DCX-remote16a
I would pay for implementing this...:clap:
Thanks and
best regards
A while ago I had a chance to setup and test a DCX2496 with a usb serial adapter. I used a FTDI usb to serial adapter but unfortunately I couldn't make it work. Not sure what went wrong but it wouldn't communicate even I spent almost 2 days trying. could that be because to the Java thing you mentioned above?
Related Threads
742.3K posts
170.9K members
Since 2006
