learn from my mistakes. - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
REW Forum
Discuss learn from my mistakes. in the Subwoofer Equalization | Calibration forum; learn from my mistakes. Playing around with REW over the weekend I noticed mistake I've made in the past that messed up all my ...
Old 05-01-07, 06:46 AM   #1 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
Playing around with REW over the weekend I noticed mistake I've made in the past that messed up all my results.
I have my USB soundcard constantly connected to the back of my AVR, when I use REW I just plug the USB plug into the laptop. The signal runs through the bass management of the receiver. To test the mains and sub integration I have both the mains and the subs on, to test the LFE channel I was switching off the power amp for the mains, instead of connecting the soundcard output directly to the BFD(can't get behind my rack).
The thing I realised after about 3 hours of tweaking my curve is, the 80hz crossover is still in the signal chain, but the LFE channel rolls off at 120hz. The crossover in the AVR needs to be reset to 120hz to measure the LFE channel. When I did this and re measured everything above 80hz was now way up on the previous measurements, 110hz was equal level to 20hz and I have a mean house curve in place.
I did my setup again from scratch and the result is a HUGE improvement over what I had previously.
Another change I made was to use a 100hz crossover instead of 80hz, it gave a lot smoother response than the 80hz, localisation won't be a problem as I have one sub behind each main speaker.
While I was on a roll I thought I'd play around with positioning of the mains, I ended up bringing them forward about 10 inches and the imaging and soundstage depth improved immensely. I've actually been sitting down listening to 2ch music for hours on end since I reposioned the speakers and made a music preset for the BFD, something I never did previously.
All in all a quite productive sunday arvo.
Hakka.
Old 05-01-07, 08:27 AM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: learn from my mistakes.
Switching off the mains power amp is the correct way of doing it actually.
The LFE does indeed extend out to 120Hz in the Dolby spec, but my understanding is that the sound engineers roll that off themselves to integrate it more smoothly into the standard 80Hz LPF (low pass filter) crossover provided by all home processors.
The actual spec'd information when given to the sound engineer goes all the way to 120Hz and then is digitally cut off. This would be horrible to listen to if sent to a sub, so I guess it's their creativity to roll it off (and a smart move).
Since the 'small setting' redirected bass is normally rolled off from 80Hz (when that's the crossover you choose) at 24dB per octave, I understand that the LFE channel is given similar roll off characteristics.
At 24dB per octave, the amount of signal left at 120hZ is quite weak. Myself, I wouldn't be concerned about any differences in setup because of the LFE channel.
Old 05-01-07, 02:50 PM   #3 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
Unfortunately not all rooms respond to speaker movement. I moved mine a foot in each direction today with no obvious change in my REW graphs. They ended up right back where they started.
Old 05-01-07, 07:23 PM   #4 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
brucek wrote: View Post
I had a large hump around 100hz , there must be a bit of signal getting through at those frequencies because after I added a filter to that peak I could hear the difference when watching DVDs and it wasn't subtle. I suppose it could depend on what the source material is and how it was mixed.
I don't have my graphs with me at the moment to show the difference in the curves.
Chris, I have moved my speakers around before and used REW and I generally didn't see much difference in the response curve. I just positioned them by ear for the best imaging/sioundstage.
Hakka.
Old 05-02-07, 02:26 AM   #5 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
Aha! I too have a 100Hz peak from my speakers. My attempts to shift the speakers around had no real effect on this peak. Each speaker was producing a different response in this area but the effects were additive. I finally managed to improve things just a little by equ-ing the subwoofer after making it "hotter" and increasing the slope of the housecurve.
May I add a few of my bloopers to your thread as a warning to others?
I should have worn ear defenders or ear plugs yesterday. I woke up this morning with a really fierce whistle in my left ear! I sit about 1 foot from the left speaker at my computer. First time I've ever bothered sweeping the speakers seriously. I usually concentrate on my subs. I must have done at least 50 fullrange sweeps above 80dB while sitting right next to my speaker. Never though about ear damage at the time. Daft really, because I usually wear my radio ear defenders without hesitation when there are high noise levels.
My latest BFD filter set must be reducing sub output by around 20dB. I did a sweep after running over to adjust a filter and had mistakenly left the BFD on another filter set. The resulting sweep nearly blew the IB into the garden! Woops!
I also did a loud sweep after quickly checking the results of my filtering efforts with organ music. Then forgot to turn the volume down to REW calibration level afterwards!
Not really a bad day for me! My wife calls me Mr Pastry after such events. (An old slapstick comic)
Old 05-02-07, 04:21 AM   #6 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
Just came across some spectra labs plots by Ikka in another thread. The movie is Flight of the Phoenix LFE channel (only took me 15 minutes to work out what FOTP was). There's some high spl 100hz stuff in there.
In the same thread the plot for War of the worlds shows that theres not much over 70hz in the LFE, all the higher bass frequencies are in the full range channels.
It looks like the upper limit of the LFE is dependant on the mix, when I watched Flight of the Phoenix I do remember having to dive for the remote in the barrel roll scene because the bass was unbearable, looking at the plot the red 100hz stuff lines up with one of my 12 db peaks. This movie might be an exception though as I have not had to do that with any others, although I could hear a difference when switching presets while watching the AVS LFE demo the other night.
I would like to see more of these plots but can't find them online.
edit: just found some more, LOTR LFE only
Titan AE LFE only
Chris, I changed from an 80hz xover to 100hz and it really helped out with the integration between mains and subs, it smoothed out some peaks that were caused by the sum of the mains and sub. It might be worth trying some different xovers if your AVR will do that.
Those full range sweeps are pretty painful at the top end, I'm gonna get some earplugs for my next session.
Hakka.
Old 05-02-07, 05:01 AM   #7 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
I have an active, dual mono crossover. No amount of crossover frequency adjustment has helped that 100Hz peak so far. Though it has just occurred to me that I could try compensating for the individual speaker response variations by adjusting the roll-off frequency independently in each channel. My wife insists I enjoy REW more than listening to the programme material! I can't think why.
Similar Threads
Learn old REW before new 4.0? Element REW Forum 2 01-22-07 11:15 PM
Do Not Repeat My Mistakes Calibrating Your Home Theater Projector geekwithfamily Home Theater, Audio and Video News 0 01-16-07 03:10 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
