REW Forum
Will my Sound Blaster Audigy 2 ZS work in REW?
Discuss Will my Sound Blaster Audigy 2 ZS work in REW? in the Equalization | Calibration forum; Will my Sound Blaster Audigy 2 ZS work in REW? That's the question will the sound blaster audigy 2 Zs work or will I have to invest in a sound ...
Views: 971 - Replies: 8
Old 05-05-07, 12:37 AM   #1
Bronze Supporter
Alias: bob
Loc: OR
User: #8070
Since: Apr 2007
  bobmills is offline
That's the question will the sound blaster audigy 2 Zs work or will I have to invest in a sound blaster live? in the REW?
Old 05-05-07, 06:56 AM   #2
Friend of the Shack
Alias: Otto
Otto's Avatar
Loc: Beautiful Colorado
User: #625
  Otto is offline
Re: Will my Sound Blaster Audigy 2 ZS work in REW?
Is it this one:
http://www.extremetech.com/article2/...1382134,00.asp
or this one:
http://www.extremetech.com/article2/...1684450,00.asp
If it's either of those, I believe it will work, as both seem to have a line-in input. If you are using PCMCIA card, I believe the input is described as a mic/line-level input, so you will have to select it to be line-level in your software. Anyway, that's the big deal -- does it have a line-level input? And it appears from my quick research on the web that both of those do, so you should be OK.
-- Otto
Old 05-05-07, 12:09 PM   #3
Bronze Supporter
Alias: bob
Loc: OR
User: #8070
Since: Apr 2007
  bobmills is offline
Sound Blaster Audigy 2 ZS digital out? will it work REW?
What I 've found so far is the soundbaster audigy is digital out and the soundblaster live analog out. I have audigy ,will digitol out work in setting up rew?
Old 05-05-07, 12:32 PM   #4
Alias: brucek
User: #6
  brucek is online now
As OTTO says........... which model is it???
You can use digital out, but you can't create a soundcard calibration file, which makes the results less accurate...
Old 05-05-07, 01:09 PM   #5
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
  Otto is offline
Hi Bob,
I believe both have analog outs. The non-laptop model lists its outputs at 7.1 and coax S/PDIF. I believe the PCMCIA card listed it as having a 1/8" jack that serves as both analog and optical out. I think it will work for you. Using digital out won't be the end of the world, but, as brucek correctly points out, you won't be able to do a sound card cal.
-- Otto
Old 05-05-07, 02:32 PM   #6
Alias: Jerm357
Jerm357's Avatar
Loc: Detroit
User: #717
  Jerm357 is offline
I have an Audigy 2 ZS and it works fine with REW. Heres the response. -1db @ 10hz
-3.4 @ 5hz
Old 06-01-07, 05:59 PM   #7
Alias: Warp
Loc: Milwaukee
User: #7217
Since: Mar 2007
  Warpdrv is offline
Jerm357, How do you have this setup with the PCMCIA card...
I would like to use this as well, so I don't have a bunch of chords and pieces running around... I'll be buying a Galaxy CM140 to get this going as well...
Warp
Old 06-01-07, 06:13 PM   #8
Alias: Jerm357
Jerm357's Avatar
Loc: Detroit
User: #717
  Jerm357 is offline
Not sure about PCMCIA. Im using the normal Sound Blaster Audigy 2 ZS PCI card. It looks like this..........
Old 06-01-07, 06:19 PM   #9
Alias: Warp
Loc: Milwaukee
User: #7217
Since: Mar 2007
  Warpdrv is offline
ahhh ... is anyone using a PCMCIA card for REW...?
I wanted to have a nice neat package without all those extra parts hanging out...
