Clicking sound during pink noise - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Clicking sound during pink noise in the Subwoofer Equalization | Calibration forum; Clicking sound during pink noise Hi, I've just started using the software, and it's very useful and fun to play with. However, whenever I play ...
Old 08-10-06, 07:16 PM   #1 (Link)
New Member
Alias: Tim
User: #1944
Since: Aug 2006
tim916 is offline
Hi,
I've just started using the software, and it's very useful and fun to play with. However, whenever I play pink noise to set the measurement level or calibrate the spl meter I also get a high-pitched clicking sound through my speakers. Has anyone else noticed this? I am using the internal sound card on my mac Powerbook. Thanks.
Old 05-07-07, 02:02 AM   #2 (Link)
Alias: michael_98101
Loc: Seattle, WA
User: #8432
Since: Apr 2007
michael_98101 is offline
Re: Clicking sound during pink noise
I'm hearing this also.
--mj
Old 05-07-07, 02:42 AM   #3 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
Not on subwoofer sweeps but when I test my speakers full range I get a horrible noise as the pitch goes higher than I can hear. A sort of tearing noise ending with a very loud chirrup. The graphs shows solid blocks of colour rather than spiky lines. I seem to have deleted all the graphs showing this effect. I do get clicks at low frequencies when I use "F follows cursor". The clicks seem to have a tempo. A quickly repeated tapping.
Old 05-07-07, 03:08 AM   #4 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
Are you using 'subwoofer pink noise' or 'main speaker pink noise', REW lets you chose. Sub pink noise sounds really bad through the mains.
Hakka.
Old 05-07-07, 03:29 AM   #5 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
Hakka wrote: View Post
Hakka.
If you were asking me... I use both.
Old 05-07-07, 03:48 AM   #6 (Link)
Loc: Seattle, WA
User: #8432
Since: Apr 2007
I hear the clicking with either.
--mj
Old 05-07-07, 03:49 AM   #7 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is online now
Do you have the audio input and output set to Default Device? That might work a little better. The audio interface on the Mac is rather problematic at the moment, looks like I'll have to generate a Mac-specific version of the app to get around that - a shame as one of the beneftis of Java should be its cross-platform capabilities, but that relies on the various platform providers properly supporting it and Apple have chosen to go with their own audio class library rather than supporting the existing JavaSound classes.
Old 05-07-07, 07:20 AM   #8 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
I used sub pink noise once with my mains still connected and remember it sounding pretty bad, doesn't sound like what you guys are experiencing though.
Hakka.
Old 05-08-07, 04:48 AM   #9 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
I keep wondering if there is a relationship between the speed of the computer processor and USB soundcard function in REW. Though I remember somebody saying they use a very old computer for REW without problems. Laptops are usually slower than PCs anyway. I usually close all other programmes when I'm using REW just to be on the safe side.
Old 05-09-07, 01:51 AM   #10 (Link)
Loc: Seattle, WA
User: #8432
Since: Apr 2007
In case this helps, I get the same clicking with two OS X machines:
1) version 4 on a 2GHz Intel Core Duo MacBook with 2GB RAM
2) version 3.29 on a 2.1GHz G5 iMac with 1.5GB RAM
As a Java developer, I sympathize with the author(s) of REW for all the problems on the Mac. We develop a Java client/server application with thousands of users that works fine on both Windows and OS X. But our product doesn't have to deal with the audio stuff that seems to be causing the problems.
--mj
Old 05-09-07, 03:50 AM   #11 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is online now
The clicking problem is related to the mixer Apple provide (which also has very high latency). I have been able to improve it by altering buffer sizes and some details of how the interface to the hardware is handled, but a better solution would be a half-decent mixer - happily, someone is currently beta testing one (Bob Lang at www.mandolane.co.uk, who also provides the Java Midi interface required on the Mac). That mixer greatly improves things, though the REW software needs some tweaks to work properly with it, so you can't use it just yet. Only downside is it is an output mixer only, so there is still the problem that Apple's mixer only allows access to the built-in hardware for audio input, haven't found a solution for that yet.
Similar Threads
White or pink noise for REW calibration? Chrisbee REW Forum 4 08-01-06 08:36 AM
Review: Yamaha YST-MS50 multimedia speakers deliver great sound on the cheap Wayne A. Pflughaupt Computers | Games | HTPC | Digital Devices 0 07-16-06 08:22 PM
House curve: What it is, why you need it, how to do it! Wayne A. Pflughaupt REW Forum 3 06-26-06 04:47 PM
Yamaha YSP-1000, Surround Sound Projection Wayde Home Theater, Audio and Video News 0 06-12-06 08:11 PM
REW - Possible?? Measuring using Pink Noise from Source Player media2368 REW Forum 8 05-16-06 01:12 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
