| REW Forum REW HelpDiscuss REW Help in the Subwoofer Equalization | Calibration forum; REW Help Hi everyone
I'm just staring out using the REW and am confused
Can anyone give me some starting out hints?... |
| | #2 (Link) | |||
| | Re: REW Help How far have you gotten? Is everything connected? Levels set? etc., etc. Oh yeah... have you read the Online HELP files? It's somewhat of a step-by-step guide. | |||
| | #5 (Link) | |||
| Re: REW Help The software is great, but not intuitive. It has taken me a while, but I'm getting better at it. The step that I kept missing was the part about getting my soundcard profiled. In this step, you unplug the cables from the sound meter and which go to your BFD or receiver, and put in a loopback cable. It then tests the soundcard against itself. Then you go back and hook everything up again. | |||
| | #8 (Link) | |||
| Re: REW Help Brucek, I don't have one, but neither do I have a laptop. I have read the thread on EQ Wizard, but really wouldn;t know how to start. I do have a Radio Shak SPL and have done LF Sweeps, I also have placed acoustics in the room, but that had no scientific approach. I probably have done as much harm as good with my placements. My room is hard to figure, because has an open space. I will post a few pictures and maybe you have a suggestion or 2. Thanks for your interest. Joe | |||
| | #9 (Link) | |||
| Re: REW Help brucek, The room is 16 x 25', viewing and listening area is 16 x 14' to the curtain divider. I have 2x8' panels or 705 in 3 corner, 2 are behind the front speakers, and 1 in the right corner facing the screen. There are 3, 2 x 4' panels on the right wall, 2 on the back wall and behind the curtains on the back wall is filled with 703. Don't know what to do with the part of the room beyond the curtains. I was hoping that the reflections were too far to worry about. I am in the process of getting a thick 8 x 12' carpet for the floor to replace the small one. As you can see, I have tried, just an old guy, 63, trying to learn something new, with little experience. It's hard. I could certainly purchase a BFD, but just reading the thread confused me. Most of the terminology, I don't understand. Thanks again for the reply. Joe | |||
| | #10 (Link) | |||
| Re: REW Help Joe, that room looks very nice. You've done a great job. Anyone that can do LF sweeps and produce a proper graph as you've done can certainly operate a BFD. You really don't need to use the REW software to set up a few filters on a BFD (parametric equalizer). The method you're using will suffice. The REW software simply makes it incredibly quick and accurate, which allows changes and observing the result in a second. To do an LF sweep and produce the hand drawn chart you've provided wouldn't be considered immediate feedback - but still effective. The change that's obviously required for your room (that you are already taking care of) is that reflective floor. Yikes, that must provide a heck of an echo. Impulse response would be interesting. The carpet will really help there. The dimensions of your room provide first order axial mode resonances at 22.5Hz, 35.3Hz and 70.5Hz. The peak at ~35Hz bears this out. That peak is in an area that will produce predominant bass levels that creates somewhat of a 'one note bass' sound. It would be nice to reduce that peak at 35Hz if possible. A BFD would do it easily. The BFD simply installs in line between your receiver/processor and subwoofer. You manually set a cut filter at 35Hz of a desired dB setting and a bandwidth at a desired width and then redo your manual LF response test and see if you've tamed the beast. It ain't too difficult... brucek | |||
| | #11 (Link) | |||
| Re: REW Help brucek, I just finished doing a sweep with just my fronts. Maybe you would be so kind as to explain this to me. My speakers are Paradygm 100's. I have the crossover set at 80 in the preamp. I have my speakers all set to small. I don't understand how the fronts are producing 87 or 88 db at the 30 thru 70 range and even 77 at 20. I am going to run a sweep now with just the sub., which is a Hsu. VTF3-Mk2 and is set behind the couch to the right of the main seating position. How do I purchase the BFD, and where? Does it act as a regular EQ? Sorry for all the questions. I have never had or used and EQ. Thanks again. Joe | |||
| | #12 (Link) | ||||
| Re: REW Help Quote:
The processors crossover settings would be where I would first be looking for a problem. Something is just not right if you have a small setting at 80 and you are producing that graph. Perhaps your measurement technique is incorrect. What Radio Shack meter calibration file are you using? What model of the three meters do you have? You need to use the correct file for the specific meter. You should use our excel measurement tool and tones found here perhaps. See the BFD Microsoft Excel worksheets and use the correct worksheet for the meter model you have. All the cal files are built into the worksheet. You can buy a BFD at most musician supply stores such as here. I'm not recommending this place specifically, it was just the first google match. The BFD acts as a simple two channel equalizer at line level between the processors sub out and your subwoofer. There are 12 filters per channel. You just use one channel if you have one subwoofer. See the Guide for a deeper explaination.. brucek | ||||
| | #13 (Link) | |||
| Re: REW Help Thanks so much for the help. I really don't understand because the processor is set to 80. I will have to do more searching. I'm not sure about my SPL, but it is an analog one. Thanks for checking on me. Joe | |||
| | #18 (Link) | |||
| Re: REW Help Now you can see I really don't know what I'm doing! Sonnie, Thanks so much for the interest. The attitude on this forum is great. I will try an do what I can, please excuse the ignorance. I tried to use the Exel Graph but this is all new to me and I'm an old guy. I will try to redo this; I hope it comes out better. I do have microsoft outlook, but have never used exel. Thanks Again, Joe joeb.gif Last edited by jbarcelona4; 06-05-06 at 07:37 AM. | |||
| | #20 (Link) | |||
| Re: REW Help I hope this works. Sonnie, this is with the sub. in the same corner but firing in the opposite direction, behind the sofa. I'm still not sure how to get the file here from the the site. I saved it to my documents and did the upload as such. Which reading do you think is best? Thanks, Joe Last edited by jbarcelona4; 06-05-06 at 03:04 PM. | |||
| | #21 (Link) | |||
| | Re: REW Help Now we got something to look at... see above! You can tame those couple peaks at 25hz and 36-40hz and maybe boost that 63hz area a tad and have yourself a pretty good lookin' house curve. REW will probably reveal more problems though. I'll post the graph here too: ![]() |
