| REW Forum When calibrating SBLive low signal levelDiscuss When calibrating SBLive low signal level in the Equalization | Calibration forum; When calibrating SBLive low signal level I've tryed resetting soundcard (SBlive) sound level plus sweep level. I'm runing a line driver into my power amp with ... |
Views: 541 - Replies: 2
| When calibrating SBLive low signal level I've tryed resetting soundcard (SBlive) sound level plus sweep level. I'm runing a line driver into my power amp with 2.5 volts output. First I bipassed the driver and ran the input staight to the FBQ2496 then I ran it through the driver same responce -Very low signal level the highest lenel in the meaurement is just -72.2 dbfs the highest level should be above -10dbfs. I getting ample output. Help please some. ![]() | ||||
| | #2 | ||||
| Re: When calibrating SBLive low signal level If you are talking about the input level being too low, then the fault is in the input not the line driver (you mean preamp?) or the 2496 or the power amp output. Nick | ||||
| | #3 | ||||
| Re: When calibrating SBLive low signal level Do you have the SB live set to the default "What you hear" instead of (the correct setting) "Line in" in the SB Live! Mixer? | ||||
