Go Back   Home Theater Shack > Subwoofer Equalization | Calibration > REW Forum
Register
REW Forum
How much boost?
Discuss How much boost? in the Subwoofer Equalization | Calibration forum; How much boost? My IB sub has amazing clarity- but it doesn't kick me in the rear. I have plenty of power to ...
Old 05-25-06, 09:41 AM   #1 (Link)
Alias: toecheese
Loc: Raleigh,NC
User: #356
toecheese is offline
How much boost?
My IB sub has amazing clarity- but it doesn't kick me in the rear. I have plenty of power to feed it, but don't know how much I should.
Ideally, I'd add more drivers, but a buddy of mine has a graph that shows doubling my drivers just adds 3db (hmmmm. Makes sense, doesn't it).
I've been playing around with my BFD and REW and gave an 8db boost at lower frequencies. Finally- a kick in the seat.
But, am I screwing up by doing this? How much boost should I feed in? What is my limit?
Old 05-25-06, 10:18 AM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: How much boost?
I depends on several things. There are frequencies in a room (that usually show up as a dip in the response) that can be fed more and more power with very little positive results. These nulls aren't solved by adding power, but by repositioning of speakers or listening positions or sometimes treatments.
Generally, if we're not talking about these nulls, and the room accepts the boost, then you can add voltage gain to a system until the power amp clips its output or your drivers reach maximum excursion (before the power amp clips). Both these conditions are fairly obvious when they occur.
Old 05-25-06, 03:27 PM   #3 (Link)
Alias: toecheese
Loc: Raleigh,NC
User: #356
Re: How much boost?
Thanks, Bruce- that's what I was hoping to hear. I know about room nulls- figure easy enough to spot, but these low spots were at the low-range of my frequencies. Looking at some of the other charts, could see I wasn't the only one boosting there.
My amp is 2400 watts so I doubt it'll clip anytime soon.
As far as excursion limits- will I know it before I find a cone lying on the floor?
Old 05-25-06, 05:37 PM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
Re: How much boost?
This is something I have no experience with. Good question.
I have read that you hear a clacking sound that is unmistakeable, but it's never happened to me. Perhaps someone else can comment on this.
Old 05-25-06, 06:21 PM   #5 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: How much boost?
Not necessarily. Some people have been led to believe that any low spot in their response is a null. This is not the case. You’ll find that most low response areas will respond to equalization, as you can see by looking at the before-and-after charts you can readily find in numerous threads on this Forum. As brucek said, you can recognize a true null by the fact that it will not respond to boosts in equalization.
brucek is right, you’ll definitely know when it happens – it makes a lot of racket. However, if you have visual access to your drivers, you should be able to tell you’re “on the verge” just by looking at them. They’ll have some pretty violent cone movement. You don’t have to worry about permanent damage, though – i.e., one time overdriving them won’t damage most sub drivers, since they’re generally fairly robust. Just back down on the volume or EQ enough to make it stop.
Old 05-25-06, 08:01 PM   #6 (Link)
Alias: toecheese
Loc: Raleigh,NC
User: #356
Re: How much boost?
I understand what you're trying to clarify- differences in speaker resonance, impedance, etc. at different frequencies can also cause nulls.
In my case, the low area I am referring to is the entire range below 35Hz or so, not a 'dip'.
Old 05-26-06, 11:46 PM   #7 (Link)
Alias: Dan
Loc: Australia
User: #359
Danny is offline
Re: How much boost?
Really you can probably safely overload your driver by twice. With mine it is rated at 300watts but I'm putting 600 through it without distortion. Speaker
distortion is easy to hear so if your hear distortion and its not your amp clipping then the driver is overloading.
Really anything below about 30Hz (depending on your age) is inaudible.
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
