Can REW measure using an external sweep? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices.
Exodus Audio
    Home Register         Shack Shopping Glossary     Enclosure Calculators Forum Help/FAQ
REW Forum
Discuss Can REW measure using an external sweep? in the Subwoofer Equalization | Calibration forum; Can REW measure using an external sweep? Is it possible to use REW to measure frequency response when I play a sweep using a test tone from ...
Old 02-27-07, 11:13 PM   #1 (Link)
Alias: lovingdvd
User: #5942
Since: Jan 2007
  lovingdvd is offline
Is it possible to use REW to measure frequency response when I play a sweep using a test tone from my HD DVD player as the source, instead of using REW to generate the sweep?
Long story short is that there is much talk about LFE level issues (bugs) with some receivers where the output is about 10dB too low when sending linear PCM to a receiver using HDMI.
Anyway, what I'd like to do is play an LFE only test tone from my player over MPCM and measure its response, then do the same with Bitstream and see what differences if any are present. Is this possible using REW? Thanks.
Old 02-27-07, 11:29 PM   #2 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
  Hakka is offline
Re: Can REW measure using an external sweep?
I don't think REW can do that but you should be able to do what you want with an SPL meter.
Harry
Old 02-28-07, 01:45 AM   #3 (Link)
Alias: lovingdvd
User: #5942
Since: Jan 2007
Hakka wrote: View Post
Harry
Yes it definitely works with the SPL meter but I thought it would be much better to have the response curve plotted and saved for reference rather than just eyeing it off of the meter "live".
Old 05-20-07, 03:15 PM   #4 (Link)
Alias: Tony
User: #9079
Since: May 2007
  tonyptony is offline
Harry
Hi everyone. I know I'm a newbie here, but I've been a long timer on both avsforum and the Slimdevices forum. I'm moving to implement DRC through my Squeezebox source. I've been reading about REW for some time now and have it just about all set up on my system (ECM8000 and Mobilepre).
To the point of the original post, I would also put in a vote for this feature. If one were to use a RS meter to set the SPL per the Calibration procedure using (assuming available) and external signal, and the Measurement function were modified to allow the option to use and External Sweep, then it could be done. My vote for this is based purely on my use of the SB as a source, and the availability of test tones for it. You could then get a room response that would automatically take into account the vagaries of the entire signal chain.
Similar Threads
sweep or sine wave ? Bergowitz REW Forum 11 11-23-06 10:09 AM
My first measure sonata31 REW Forum 48 11-17-06 01:29 PM
Baseline graph 15-200Hz sweep - do I need bass traps? pclausen REW Forum 14 10-26-06 12:21 PM
measurement from external sweep? eddthompson REW Forum 2 08-31-06 09:52 AM
complete noob: can REW be used to measure stereo response? tboooe REW Forum 8 06-26-06 03:21 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227
