| REW Forum About to take the REW/BFD plunge…A couple questions pleaseDiscuss About to take the REW/BFD plunge…A couple questions please in the Equalization | Calibration forum; About to take the REW/BFD plunge…A couple questions please Well, I’m about to place an order for all of the equipment I need to get my REW/BFD up and ... |
Views: 664 - Replies: 7
| About to take the REW/BFD plunge…A couple questions please Well, I’m about to place an order for all of the equipment I need to get my REW/BFD up and running. A couple of thoughts questions as I have gone from thoroughly confused at the start to moderately confused. This forum is invaluable, thanks in advance for your hard work! I know once I get everything hooked up I hope all the answers can be found here. I will most likely go with the FBQ2496 over the DSP1124P due to the required additional firmware needed by the DSP and the requisite surgery to install. My understanding (please correct if I am wrong) is that the FBQ2496 can only store one set of curves verses multiple curves for the DSP1124P (not a concern to me as this will be in a dedicated HT setup as I have a dedicated 2 channel setup in another room). The FBQ2496 is a higher res/lower noise unit (I know that is not a big deal in the sub world). My biggest concern is whether there are enough FBQ2496 owners in this thread to help me if/when I have problems or questions? The DSP1124P is used by many here, so that is very good! I will also get the Xenyx 802 mixer and the ECM8000 mic. Now for some other help: I have a RS digital sound level meter. Should I get the analog version? Thoughts please? Is the Sound Blaster Live! 24-bit External USB Sound Card the sound card of choice by most here? Are there better alternatives? Midi Interface: Has the Edirol UM-1X USB MIDI interface cable been replaced with the Edirol UM-1EX 1x1 USB MIDI interface cable? Will it work as well as the previous one? I can get this at the Academic Superstore for 34.95 shipped. Besides cables what else is needed? Thanks for all your help. ![]() Alan B. ps i hope this is me shortly.... ![]() | ||||
| | #2 | |||||||||
| Re: About to take the REW/BFD plunge…A couple questions please Quote:
Adapters to connect RCA to 1/4" balanced. brucek | |||||||||
| | #3 | |||||
I would also like to know if the MINI MIC800 http://www.behringer.com/MIC800/index.cfm?lang=eng would be a good substitute? Picked up an M-Audio UNO for CN$38.95 at a local music supply store and it works fast. | |||||
| | #4 | |||||
brucek | |||||
| | #5 | ||||
| Re: About to take the REW/BFD plunge…A couple questions please Thanks for the reply brucek. It looks as though the preamp modeling selector has a "neutural" position at #1, but there is no "off/defeat" for the low cut filter! | ||||
| | #6 | ||||
| Re: About to take the REW/BFD plunge…A couple questions please Yeah, the lowest cut appears to be 15Hz. If you got creative you could use REW to take a frequency response of this device and so modify the soundcard.cal file to compensate for the filter down to 10Hz and create a flat response (I do this with my 802 to make it super flat down to almost 0Hz). Not too big a deal, but for $20 more you can just buy the 802, which is a real cool toy and works great with the ECM8000...... brucek | ||||
