No subwoofer signal output when using REW - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 9 Old 10-04-11, 10:22 AM Thread Starter
Ghostrider333
Hi guys, need help in resolving the issue of no subwoofer output with my setup of calibrated ECM8000 mic with M-Audio Pre USB (2nd Generation) soundcard on windows 7. The calibration process went without issues and I can actually hear test tones from my mains except the subwoofer. Connection from the soundcard output is 6.3mm TRS to stereo RCA jacks to my onkyo 5008 receiver AUX input. Tested it out on my bedroom yamaha RX-V1800 receiver with the same issue. Any ideas what I can do other than connecting it directly to the subwoofer which would defeat the receiver crossover setting?
Ghostrider333 is offline
post #2 of 9 Old 10-04-11, 10:35 AM
Re: No subwoofer signal output when using REW
The only 6.3mm TRS ( stereo ) jack on that unit ( that offers L&R output ) , is the headphone output .
Is that where your cabling is plugged into ?
<> EarlK
EarlK is offline
post #3 of 9 Old 10-04-11, 10:40 AM Thread Starter
Ghostrider333
Hi EarlK, the 6.3mm TRS jack is plugged into the line output 1 at the back of the soundcard and not the headphone jack.
post #4 of 9 Old 10-04-11, 10:54 AM
That's not a stereo output jack . It's a balanced ( mono ) output .
Buy the correct cabling ( two, separate TRS to RCA mono cables) and those problems should be resolved .
<> EarlK
EarlK is offline
post #5 of 9 Old 10-04-11, 10:57 AM Thread Starter
Ghostrider333
Ooops....thanks for the info. Will need to source for the cables once I have the time.
post #6 of 9 Old 10-04-11, 11:21 AM Thread Starter
Ghostrider333
The REW cable connection guide shows a mono line out to the receiver for the USB soundcard. Isn't that similar to my case? How is it that I need to two mono cables whereas that connection doesn't?
post #7 of 9 Old 10-04-11, 02:46 PM
> My suggestion allows you ( using REW in WDM / Java driver mode ) to send output through both outputs of the soundcard , to your left / right receiver channels . But you are right / one really only needs a single cable to get going .
> You could just use a single channel of output from your soundcard ( TRS/TS to RCA ) and then split that mono RCA to 2 more ( mono ) RCAs ( if you want to drive both receiver channels at the same time ) .
> The choice is yours ( they'll both work and give you two channels of playback , though typically you should start by testing one box at a time, adding in the sub to check the blend & then other channels later ).
<> EarlK
EarlK is offline
post #8 of 9 Old 10-04-11, 05:58 PM Thread Starter
Ghostrider333
I do get 2 channel playback signal on my mains with the current mono signal to the left and right aux input from the mono line-out connection. The only issue is the subwoofer is not outputting anything? I physically checked if there is any movement using my hands and ears close up and nothing.
post #9 of 9 Old 10-04-11, 06:16 PM
You're sub-woofer will continue to output what it's fed by your AVR / which right now is a mono synthesized bass signal that's derived from both L&R channels which currently ( most likely ) have opposite polarities ( phase to the noobs ! ) .
Add ( 180 with -180 ) and one gets nothing, nada, zippo .
Get the correct cables ( or unplug one of those inputs / just turn your levels down first ).
EarlK is offline
output , rew , signal , subwoofer
