Hi all.
First sorry for my poor english, but i will try to explain my problem.
I installed REW and i did all the steps off calibration sucessfuly, than i measured my control room with my KRK speakers and then i use the eq settings to create the filters adjustment to put on a plugin o cubase using the values generated with rew .
Everything seems ok but when i listen to the final result it sounds very very bad
How can i explain wat i listen ... very hard on top and mid frequencies and cut almost every low mid and sub.
Could be me did something wrong? one thing i was thinking is i know theres curve A and C off ponderation could be something to do with that?
Sorry for so confusion but that's the best i can explain...
