Go Back   Home Theater Shack > Subwoofer Equalization | Calibration > REW Forum
Register
REW Forum
Should I EQ??
Discuss Should I EQ?? in the Subwoofer Equalization | Calibration forum; Should I EQ?? I’ve been lurking on these forms for the last few weeks….the information here is great! I’ve been taking measurements of ...
Old 06-04-07, 06:49 PM   #1 (Link)
New Member
Alias: 420247
Loc: Halifax Nova Scotia
User: #8927
Since: May 2007
420247 is offline
Should I EQ??
I’ve been taking measurements of my sub and adjusting its position.
Below is a graph of my measured response.
I let REW find peaks, and assign filters. I manually entered those into the dsp1024.
I re-measured, and once again let REW assign filters.
The corrected response is also shown.
My question……do I need an eq….it seems as if I’m just dropping the overall level??
Thanks for the input!
Old 06-04-07, 06:52 PM   #2 (Link)
New Member
Alias: 420247
User: #8927
Since: May 2007
420247 is offline
Re: Should I EQ??
Old 06-04-07, 06:54 PM   #3 (Link)
New Member
Alias: 420247
User: #8927
Since: May 2007
420247 is offline
Re: Should I EQ??
SB live External
RS meter
Paradigm Servo 15a
Old 06-05-07, 04:43 PM   #4 (Link)
Alias: Edward
Loc: Brampton ON, Canada
User: #8188
Since: Apr 2007
clubfoot is offline
Re: Should I EQ??
What do you have your xover set to on the sub measurements?
Old 06-05-07, 05:02 PM   #5 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Should I EQ??
If you like the target that you are using, then you have successfully brought the level of the sub down to track it properly.
You had a large peak from 20hz to 60Hz which you removed. Many people might like to take advantage of that rather smooth peak to create a bit of a house curve - others might not. If you're a 'not', then you've done the correct thing.
Old 06-05-07, 06:46 PM   #6 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: Should I EQ??
420247 wrote: View Post
Yup – what you’ve accomplished is dropping your sub level something like 20 dB. The equalizer should not be used as a level-adjusting device. I suggest lowering your sub’s volume control to where it’s close to the target level, then equalize.
You might want to consider experimenting with different locations, to see if it helps the 70 Hz / 90 Hz depressions. If it’s not in a corner, that’s usually a good starting place, if your installation allows.
Old 06-05-07, 07:07 PM   #7 (Link)
New Member
Alias: 420247
User: #8927
Since: May 2007
420247 is offline
Re: Should I EQ??
Thanks for the feedback!
to answer the questions...the crossover is set at 80Hz
I've been adjusting the placement of the sub, this location offered a response that seemed very smooth, except for the 70 and 90hz dip....I think i will adjust the position more, to remove those nulls, even at the sacrifice of adding some peaks....cause i already own a BFD to tame them down.
All these graphs.....i havn't even had a chance to do any listening.....music calls!
Once again, thanks, this site is great!
Old 06-05-07, 07:12 PM   #8 (Link)
New Member
Alias: 420247
User: #8927
Since: May 2007
420247 is offline
Re: Should I EQ??
the crossover is set at 80hz...not sure of the slope thou.......once i get the sub looking good upto 80hz I'll start testing with my mains on .
I have the advantage of having the x-30 control unit from paradigm, 180deg varible phase and crossover
Old 06-05-07, 09:29 PM   #9 (Link)
Alias: Edward
User: #8188
Since: Apr 2007
clubfoot is offline
Re: Should I EQ??
If you have your sub xover control set to 80Hz, increase it to the max and remeasure. You may find that it follows the target curve more closely, and as Wayne suggested lower your sub output first, then EQ, it will need very little.
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
