REW Forum
Another "Need help with soundcard" situation.
Discuss Another "Need help with soundcard" situation. in the Equalization | Calibration forum; Another "Need help with soundcard" situation. I've searched and read many threads and I've come to the conclusion my problem sounds like it is an internal ...
Views: 653 - Replies: 9
Old 06-08-07, 08:37 AM   #1
Alias: whoaru99
User: #9426
Since: Jun 2007
  whoaru99 is offline
I've searched and read many threads and I've come to the conclusion my problem sounds like it is an internal loopback problem.
When I try to cal the soundcard I get an input signal even with nothing plugged into the soundcard jacks.
When I try to run a measurement I get a mirror image of (I believe) the sound card cal file.
When I try to use the RS meter as a microphone it produces no sound via the computer.line-in, but plugged into an AUX input on the stereo it does work as a microphone.
The sound system is onboard sound using Realtek ACL883 chipset. I have spent hours combing the settings of REQW and Windows (XP) and the Realtek features/settings and have come up lacking a solution. I did find a "stereo mix' setting, but I have tried that selected and de-selected and it seems to make no difference. I have changed the settings, rebooted, and tried again and again to no avail.
Any suggestions as to what I'm missing? I know it's gotta be something simple.
As a side note, I have used REQW before on a different computer and sound card that I no longer have. So, it's not like I'm a total noob on this, and that's probably what's frustrating me the most...
Old 06-08-07, 08:55 AM   #2
Friend of the Shack
Alias: Otto
Otto's Avatar
Loc: Beautiful Colorado
User: #625
  Otto is offline
Re: Another "Need help with soundcard" situation.
Hi there whoaru99,
I was looking around on the web for your problem but didn't come up with much. Do you have the latest drivers? That seemed to take care of some people problems (different problems, though).
-- Otto
Old 06-08-07, 09:03 AM   #3
Alias: brucek
User: #6
  brucek is online now
Can you post your Windows mixer settings (record and playback)?..........................
Old 06-08-07, 09:06 AM   #4
Alias: whoaru99
User: #9426
Since: Jun 2007
  whoaru99 is offline
Yes, I can post the settings, but off to work now. I'll try to get them posted at lunch time.
Old 06-08-07, 01:49 PM   #5
Alias: whoaru99
User: #9426
Since: Jun 2007
  whoaru99 is offline
Well, guess what? Seems to be working now.
I checked the driver revision for the ALC883 chipset and mine was two revs old. So, I downloaded the most current rev, uninstalled the old ones and installed the newest.
Fired up REQW, cleared all settings and started from scratch (which I had previously done NUMEROUS times). I didn't change any other settings except selecting the sound card and appropriate inputs from the pull-down lists in the soundcard cal screen.
Went though the soundcard cal ensuring the input signal was from my loopback connection. Went through the SPL cal, again ensuring that the input was from the RS meter and that went fine.
So, ran a sweep and got about what I was expecting the first time through.
Don't know for sure if it was the driver itself, or the uninstall/reinstall process that reset something.
Thanks for your concern and suggestions. As the old adage goes "if it ain't broke don't fix it" and it seems it ain't broke any more.
Old 06-08-07, 01:50 PM   #6
Alias: brucek
User: #6
I'm sure we can figure out the problem.
I use the ALC850 AC97 RealTek on board audio chipset, and it works fine.......
Here's my settings. Do yours match?
Name:  Mixer record.jpg
Name:  Mixer Playback.jpg
Name:  Check Levelsxxxxx clear.jpg
Old 06-08-07, 02:12 PM   #7
Alias: whoaru99
User: #9426
Since: Jun 2007
  whoaru99 is offline
brucek,
The settings that seem to be working are not all like yours in the Windows mixer controls.
The 883 has so many output settings that I had to break the output mixer panel into two pictures - and it still didn't show the CD settings (muted) at the far right of the second output mixer picture.
Also included is the first sweep, but this is of a main speaker, full range, and no RS cal file loaded.
Old 06-08-07, 02:23 PM   #8
Alias: brucek
User: #6
OK good, a couple of problems.
Make sure the RealTek software has 2 channel selected and not any 5.1 or 7.1 etc.
I would also let REW control the volumes. Click the boxes shown below and let REW run the show.
That's a start anyway.....
Old 06-08-07, 03:35 PM   #9
Alias: whoaru99
User: #9426
Since: Jun 2007
  whoaru99 is offline
Great!!
I'll change the REQW control settings and check/set the speaker details tonight.
Thanks for the additional info.
Old 06-08-07, 03:48 PM   #10
Alias: brucek
User: #6
Yeah, I'd Mute the Mic and CD also............
I trust you're using (mono to stereo 1/8" adapters) at the line-in and line-out jacks of the soundcard...
