Go Back   Home Theater Shack > Subwoofer Equalization | Calibration > REW Forum
Register
REW Forum
EQed sub, now how do I intergrate it?
Discuss EQed sub, now how do I intergrate it? in the Subwoofer Equalization | Calibration forum; EQed sub, now how do I intergrate it? Hello, here is a graph of my sub frequency response, before and after. I am very happy with the result, ...
Old 06-07-07, 04:16 AM   #1 (Link)
Alias: Jamie
Loc: Waikerie, South Australia
User: #9297
Since: May 2007
wilsonj is offline
Hello,
here is a graph of my sub frequency response, before and after. I am very happy with the result, using a ~15db house curve from 80 to 20. But does anyone have tips on how to integrate this with the rest of the system?
Blue is the un BFD curve.
I only use this system for HT.
Do I measue each L R C speakers seperately. It seems rather difficult to do, as my processor sends different amounts of signals to different speakers depending on what mode it is in. eg Logic7 or DD.
And what sort of full range curve should I be trying to achieve? +-3db? Or is that a little too much to expect (I think it is)
I'm really at a bit of a loss on how to go about this.
Cheers
Jamie
Old 06-07-07, 08:14 AM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: EQed sub, now how do I intergrate it?
Do I measure each L R C speakers separately. It seems rather difficult to do, as my processor sends different amounts of signals to different speakers depending on what mode it is in.
To measure and test the sub, you likely fed the AUX or CD input of the receiver and had the mains disconnected. You likely used stereo mode, since that mode doesn't use any decoders etc. Use this same mode to integrate the mains.
Simply turn on the mains (you need to feed the AUX or CD input with a 'Y adaptor' to get both mains on). Now measure the sub just as you did when the mains were disconnected. (except be sure to make the end frequency entry into the measurement panel at 200Hz - in your sub graph you cut it a little shorter than that).
The level balance between the sub and mains is up to individual taste. Some want to end up with a straight flat response and others want the sub quite a bit higher than the mains. It's up to you. What you do want to look for is how the crossover area looks since the combining of the mains and sub can cause peaks and valleys at the crossover frequency. Usually sub phase control will eliminate this.
The rest of the speakers in the system are simply set to the level of the mains using the receiver test tones routine...
I attach two examples to show you that peoples tastes differ.
The first graph is from a bass nut who has his sub much higher than his mains (but crosses at 60Hz). The nut happens to be me.
The second is from a member here who has the sub and mains flat...
Old 06-07-07, 06:39 PM   #3 (Link)
Alias: Jamie
User: #9297
Since: May 2007
wilsonj is offline
Hi Bruce, thanks for your reply.
OK I did what you said and found the sub was out of phase to start with. BIG dip in the curve. Fixed that and played with the xover points for a while, but not having the perfect placement for my fronts (one is backed into a corner) and no other EQ there is not much else I can do for now.
One other question. What about the centre?? Is there anything I can do for that? I can't run all 3 fronts and sub at once anyway. I guess the only thing I could do is check the phase?
Here is my latest graph. The bump at about 132hz is from the mains, and I can't get rid of it.
Cheers
Jamie
Old 06-07-07, 06:44 PM   #4 (Link)
Alias: Jamie
User: #9297
Since: May 2007
wilsonj is offline
Oh the other thing to note is that my house curve has disappeared!! Looks like it was swallowed up by the xover point. But it still sounds very good to me, in fact the bass is almost overpowering at times. Like the knocking of the glass tank scene in Finding Nemo.
Old 06-07-07, 07:08 PM   #5 (Link)
Alias: brucek
User: #6
brucek is offline
The assumption is that if the sub integrates well with the mains, then the center should be fine.
Your response and integration is very good. Always best to start flat as you've done, and if it sounds good at that point, you're finished...
Old 06-07-07, 08:17 PM   #6 (Link)
Alias: Jamie
User: #9297
Since: May 2007
wilsonj is offline
I just checked that all my other speakers were in phase, which they were. And I guess that it can be assumed the centre should be the same as the L and R speaker, as you stated. Makes sense to me!
Thanks again for your help. What a great forum!
Cheers
Jamie
Old 06-16-07, 04:22 PM   #7 (Link)
Alias: Tweakophyte
Loc: Boulder, CO
User: #1615
tweakophyte is offline
If it ain't broke, don't fix it...
...but...
For others reading this there are few things you can do to integrate the sub and mains. Since you can measure a lot with REW you can play with both phase and x-over. The trick is, instead of playing with the phase dial you can change the sub's distance in set-up options on your reciever.
Before or after that you can play with the x-over frequency.
Again, since the measuring is automated you can tweak to your heart's desire.
Old 06-16-07, 04:42 PM   #8 (Link)
Alias: Jamie
User: #9297
Since: May 2007
wilsonj is offline
Ahhh, another great idea. Hadn't thought of that one!
Old 06-17-07, 07:31 AM   #9 (Link)
Alias: Tweakophyte
Loc: Boulder, CO
User: #1615
Ed Mullen gave me that trick.
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
