I want to simplify my equipment setup, can I do this? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss I want to simplify my equipment setup, can I do this? in the Subwoofer Equalization | Calibration forum; I want to simplify my equipment setup, can I do this? Currently I have a ecm8000 mic hooked up to a Behringer 802, for phantom power and an M-audio 24/96 external ...
Old 06-24-07, 07:42 PM   #1 (Link)
Alias: Jamie
Loc: Waikerie, South Australia
User: #9297
Since: May 2007
wilsonj is offline
Currently I have a ecm8000 mic hooked up to a Behringer 802, for phantom power and an M-audio 24/96 external sound card.
The soundcard is not USB bus powered, and it appears to me that the 802 is possibly overkill for mic power. The power cords are a pain... I also don't use this equipment for anything other than calibration nowdays.
Could I sell both of these units and switch to an M-audio mobilepre ? Without causing myself too much trouble? Or am I better of sticking with what i have?
My main concern really is loosing the ability to easily adjust the mic input on the 802. I gather I can still do this just from inside the soundcard software?
Thanks for your input. (pun intended)
Old 06-24-07, 07:54 PM   #2 (Link)
Alias: brucek
User: #6
brucek is online now
Re: I want to simplify my equipment setup, can I do this?
Yep, several members here use the M-Audio molbile Pre with good results. It has its own phantom power and mic preamp..... The Mobile Pre has its own gain knobs if I remember. Just download the manual and I think you'll see it would be fine....
Old 06-24-07, 08:14 PM   #3 (Link)
Alias: Jamie
User: #9297
Since: May 2007
wilsonj is offline
Thanks brucek, I have read a few of the threads relating to this unit. The only issues I saw were relating to not being able to include the mic preamp in the cal loop. But then I can't do that now anyway, so nothing lost.
If I am going to start from scratch, is there any other product I should consider?
Old 06-24-07, 08:57 PM   #4 (Link)
Alias: brucek
User: #6
No, I think you've got the right stuff, either way. Certainly the ECM8000 and 802 is a great combination, but the M-Audio Mobile pre along with the ECM mic is very good also.....
Similar Threads
My equipment... Sonnie Home Theater Equipment 4 04-24-08 09:18 AM
My Setup weeZ Home Theater Gallery 5 03-29-07 10:32 PM
Steve's Equipment srckkmack Home Theater Equipment 0 03-07-07 01:14 PM
Some new, some old...equipment that is. ground_wire Home Theater Equipment 4 01-22-07 09:04 PM
My equipment loupy31 Home Theater Equipment 0 06-15-06 12:15 AM
Mach 5 Audio
