Does Windows XP updates mess with REW? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Does Windows XP updates mess with REW? in the Subwoofer Equalization | Calibration forum; Does Windows XP updates mess with REW? I have a computer which is used only for REW, running Windows XP. I have not changed any settings. Only ...
Old 06-29-07, 10:15 PM   #1 (Link)
Music Moderator
Alias: Ron
Loc: Dallas, Texas
rcarlton's Avatar
User: #262
rcarlton is offline
I have a computer which is used only for REW, running Windows XP. I have not changed any settings. Only changes are updates to Windows XP and Java. Now I can't get REW to work with either my ECM8000 or RS meter.
Figured I would use system restore. Get a message that system restore does not work...
Have a similar problem with my main computer, the HP scanner no longer works after an XP upgrade. Am I the only one who is having similar problems?
Ron Carlton
Dallas, Texas
Downstairs: oiled Oak Klipschorns, LaScala (rears), oiled Walnut Heresy II (center), oiled Bubinga Heresy I (rears), SVS PB12-Plus/2 piano black, Outlaw 990, McIntosh MA6100, (2) MC250, MC2100, Oppo DV-981HD, Toshiba HD-A2, Cambridge Audio Azur 640C, Belkin Pure AV PF60, Behringer DSP1124P
Upstairs: McIntosh C2200, MC275 MKIV, oiled Walnut Cornwall I, Denon DVD-2200, Technics SL-1200 M3D, Audio Technica AT150MLX, Richard Gray Power Company 400 Pro
Old 06-30-07, 12:28 AM   #2 (Link)
Alias: Jim
Loc: Wetumpka
User: #630
JimP is offline
Re: Does Windows XP updates mess with REW?
Ron,
I've found that if I unplug then replug my external sound card from my laptop, it'll change the settings in the soundcard setup window to the system default settings. REW won't run correctly without my changing them back.
Check those settings in case they're getting changed unknowingly.
Old 06-30-07, 04:58 AM   #3 (Link)
Alias: brucek
User: #6
brucek is offline
I've had no problems... and I do get the regular XP updates too.
Under the Settings pulldown in REW, try the Delete Settings and Shutdown function. Then restart and set your preferences back up. Maybe that will clear the problem.
Old 07-01-07, 05:59 PM   #4 (Link)
Music Moderator
Alias: Ron
Loc: Dallas, Texas
rcarlton's Avatar
User: #262
rcarlton is offline
Got it working. Unplugged the soundcard, turned computer on, turned it off (rainstorm coming). Turned it on with soundcard plugged back in and all is well. Thanks guys!
Ron Carlton
Dallas, Texas
Similar Threads
Don't mess with momma... Sonnie Chat Box 0 04-03-07 04:49 PM
Error Message on Windows Vista eliaspm15 REW Forum 1 11-16-06 06:58 AM
IBM PC Meets Windows 1.0 Wayde Home Theater, Audio and Video News 0 09-27-06 01:50 PM
Any Updates on the SVS Giveaway? MrPorterhouse SVSound 1 09-05-06 01:56 AM
Have you registered for BD-P1000 Firmware updates? Wayde Home Theater, Audio and Video News 0 08-19-06 01:51 AM
Mach 5 Audio
