Audio General, Inc.: Great deals on projectors, screens and electronics. Epik Subwoofers manufactures world-leading high performance subwoofers for die-hard home theater and music enthusiasts who won't settle for anything less than the best. Power Sound Audio designs, develops, and assembles high quality loudspeakers and subwoofers for home theater environments. Visual Apex: The most competitive pricing for home theater projectors... and built on customer satisfaction! OPPO Digital - Universal Network 3D Blu-ray Players - Buy Direct from the Manufacturer KEN KREISEL Sound & Design Genelec: Active Speakers and Speaker Systems Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Emotiva is your Home Theater Component Source for Audiophile Quality Home Theater Equipment at Factory Direct Prices RAM Electronics: Audio, Video, Home Theater and Computer Cables. GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Check out the Woot product for today! Parts Express: Excellent Source for DIY Speaker and Subwoofer Projects! DIY Parts and Accessories as well as custom built cables. Fast worldwide shipping. Madisound Marantz Value Electronics: A trusted retailer and custom installer that specializes in whole-house audio, home theater, Plasma, LCD, LED, HDTVs, Blu-ray and more. Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! SVSound GR Research - Offering audiophile quality loudspeakerkits, high quality crossover components, drivers and accessories. Also providing a wide range of design services from complete commercial product line design to assistance with individual custom products and upgrades.
Home Rules Register Gallery Glossary FAQ
Room EQ Wizard
Go Back   Home Theater Forum and Systems - HomeTheaterShack.com > Equalization | Calibration > REW Forum
Donations Reviews Vendors
MiniDSP: Digital audio Signal Processors (DSP) engineered to fit a wide range of applications.
Views: 714 - Replies: 4
Old 02-11-12, 10:35 PM   #1
Ryan
Since: Apr 2009
Eastern Minnesota
  NegativeEntropy is offline
I started this thread.
Initial REW results in multipurpose room, opinions are welcome
Hello,
In http://www.hometheatershack.com/foru...oom-setup.html I asked about hardware. I ended up with the Tascam US122MKII and a Dayton mic, calibrated by Cross Spectrum labs. I also picked up an inexpensive mic stand and clip.
The setup has worked well (insofar as it has behaved as expected).
The room in question is setup as described in this early thread here, with the sub in the corner location shown. Please note the asymmetry. Major changes are a no go (e.g. moving the main speakers to another wall); small changes (exact speaker, seating locations) are a possibility.
Mains are Ascend Sierra Towers, sub is Rythmik FV12.
I experimented with sub position by placing it in the main listening position, then running sweeps with the microphone at viable listening positions. The best one ended up being the corner, with the speaker facing toward the far side of the room.
The main speakers are ~3' from the wall behind them. The room itself, including next to the main speakers, is asymmetrical as shown in the linked thread.
I chose the crossover frequency by running sweeps and varying the crossover from 40-80 Hz. 70 Hz gave the smoothest frequency response graph. I did the same with sub phase after running audyssey, 180 degrees ended up being the setting that produced the smoothest graph.
I tried to evaluate my results based on this paper.
Everything looked pretty good except for the very low frequency decay (<35Hz) and potentially for a "peaks smooth in pattern density" in the ETC. Unfortunately my ignorance is vast here, even after reading here and elsewhere for some time.
Frequency response of both individual left, right and sub is good post Audyssey, as well as the combined result which measures +/- 4dB from 17Hz to 24kHz with 1/3 octave smoothing when I trim the sub for a flat response (my standard setup includes a bit of a house curve, at least as much as can be accomplished w/o an outboard EQ).
Inserted below are the ETC results for the left main, the first showing 40 ms after peak, the second 500 ms. This is measurement sweep #1 in the attached REW file.
Next is the same for the right main. These are sweep #2 in the attached REW file.
Next is the frequency response of the sub + both mains, smoothed to 1/3 octave. This is measurement #3 in the REW file. This shows a ~10 dB house curve.
Last is the low frequency waterfall for the same sub + both mains measurement. It exhibits significant ringing at 20 and 26 Hz.
I welcome any suggestions on both interpretation as well as reasonable measures to improve things. I think it sounds good today, but, for example, if an outboard EQ or wife approved room treatments would help appreciably, they are a potential option.
Thanks!
Old 02-12-12, 01:15 AM   #2
SAC
Banned!
SAC
Since: Dec 2009
CST
  SAC is offline
Re: Initial REW results in multipurpose room, opinions are welcome
A few comments about process.
First, this is an iterative process, not an all in one do everything at the same time operation.
First, the crossover issues is to resolved and corrected. It is not some step in the room correction process.
And a NECESSARY part of the crossover configuration is the signal alignment of the sources.
After that is done, then focus on the modal behavior.
And please loose the FR smoothing. We are not trying to sell this or to make things 'look' nice. Instead we WANT to know the detailed issues that are obscured by smoothing! (Sorry, not angry with you, but seeing this predilection with smoothing remain an almost universal fixation with folks who claim that they want to identify and resolve problems in the process of obscuring them grows old...)
First map the space. The mapping of the region can be done via waterfalls, or if you are not comfortable with this, perhaps more easily by the playing stepped tones (in REW) in order identify modes and to then identify the location of regional peaks and nulls. Assuming L/R symmetry, explore the region about the desired listening position, both forward and backward from the current position, in order to determine the location least subject primarily to modal nulls, and then to a lesser degree to peaks. A problem avoided by relocation is much easier than attempting to utilize brute force.
Then you will want to employ 'pink fluffy' Superchunk style porous corner traps featuring 6mil or greater faced fronts. And then after bass traps are installed and the space remeasured, one may then choose to employ limited EQ to mitigate the PEAKS (only, and then only up to 3dB) for modal peaks below 80 Hz.
After all of this is done, THEN individual ETC responses are derived for each source.
You will want to resolve each of the high gain sparse indirect energy arrivals into their vector paths and point of incidence.
A couple quick observations about the ETC above....aspects that can provide a quick indication of potential issues.
First, is the direct arrival REALLY at ~35 ms, or 39.6 FEET from the source speaker?!? I suspect not.
Thus, depending upon the method you intend to use to resolve the vector paths, you might want to consider using the hardware loopback correction for system propagation delay so that the arrival times displayed are accurate.
Also, you have quite a few significant sparse (isolated) high gain 'reflections' relative to the surrounding space, as well as a at least 4 Very significant late arriving indirect returns.
But becoming overly concerned with specifics aside from the basic configuration of the ETC process at this point is premature. Now just focus on configuring the platform in anticipation of the measurements to be performed with the mic remaining in the same precise position (a position 'marked' so that it can be Precisely re-established at any point in time later).
Also, when you do post results, please post the REW .mdata files.
Old 02-12-12, 10:14 AM   #3
Wayne A. Pflughaupt's Avatar
Katy, Texas
My Photo Gallery
Hey Ryan,
I notice that your frequency response graph shows a really low level. Did you do the SPL calibration routine? If you did and this is your actual measurement level, then it is low enough that ambient room noise might be encroaching on the results.
Of course, you don’t necessarily need to do the SPL calibration; it only means the vertical graph dB markings aren’t relevant in your case. As long as REW didn’t indicate low level or clipping when you took the measurement you’re fine.
As you have probably figured out, 1/3- or 1/6-octave smoothing for the upper frequencies eliminates the comb filtering most untreated rooms display lets you see the underlying trend in response. It looks like you have a fairly large plateau between ~1500-2500 Hz. It’s broad enough and “tall” enough (~4 dB) to probably be audible. You might be able to address this with your receiver’s built-in equalization.
A separate unsmoothed graph breaking out the bass frequencies (below 200 Hz) would have permitted better evaluation of what the sub is doing, but it looks like you’ve adequately smoothed response. However, the plateau between 30-60 Hz might be making the bass sound a bit bloated. House curves often sound best with a sloping curve that plateaus at about 23-30 Hz. It will most likely require an outboard EQ to accomplish this.
Re the low-freq ringing the waterfall graph displays, there isn’t much you can reasonably do for ringing below ~50 Hz or so. It doesn’t appear than you have any significant room modes or nulls.
Old 02-12-12, 10:50 AM   #4
Ryan
Since: Apr 2009
Eastern Minnesota
SAC,
Thanks for responding.
SAC wrote: View Post
Crossover setting:
Please describe the issues apparent with the crossover. My apologies that it is not clear to me that there are issues by looking at the measurement results.
My mains are capable to 40 Hz, so that is not a limiter. I took sub+mains sweeps with the crossover at 40-80 Hz in 10 Hz increments. A crossover setting of 70 Hz produced the visually smoothest response (with no or at most 1/24th smoothing).
What is the proper method for determining the crossover frequency? I will gladly read a reference source if you could point me to one.
Phase alignment of sub to mains: I have read of a few ways to do this. One is using the group delay plots, but these are usually too noisy to properly judge at the low frequencies a crossover is at. My experience was similar.
I adjusted the sub phase until the sub+mains SPL was loudest when playing a sine wave at the crossover frequency (70 Hz). Comparing frequency sweeps at 0, 90 and 180 degrees confirmed 180 gave the visually smoothest results.
Again, I would gladly read a reference source for the proper way to do this if my approach is not appropriate (e.g. I'm not trying to ask you to write paragraphs in response - I recognize responding in detail is time consuming).
Heh, I understand your frustration with smoothing. I only used some because otherwise the High frequency response is unusable; 1/3 seems to be standard for above ~250 Hz and below that none or 1/24th? I guess I should have broken it into 2 different plots.
I did this when selecting a location for the subwoofer but limited myself to the frequency response graphs. Will this not show peaks/nulls?
I have not experimented with relocating the mains. I will do so. I also have port plugs coming that will grant more placement flexibility for the mains (they have a rear port).
Unfortunately, bass traps are likely a no go. This is a multipurpose space, not a dedicated theater and the WAF is not there.
I was using a loopback cable. The receiver has 14' distance for the mains in it (which matches the distance measurements), but even with that (14' receiver delay + 14' actual propagation delay), as you indicated, it does not add up to 35 ms. I should have noticed this and investigated. Perhaps I was using the loopback incorrectly. I'll have to play with this more when the time comes.
Regarding mic position, yes, I will have to break out the plumb bob and painters tape as you advised in another thread.
It was attached (hence my references to it in the text).
Old 02-12-12, 11:11 AM   #5
Ryan
Since: Apr 2009
Eastern Minnesota
Hey Wayne, thanks for responding.
SPL was calibrated, I was just taking these sweeps while the wife and kids were sleeping, so I moderated the levels a bit. If memory serves, I had REW generating the sweep at -15dB and it resulted in a remaining headroom of between 10 and 15 dB (still in the green). Background noise level was 25dBA.
So, given that, do you think the levels were too low? REW did not indicate a problem.
Unfortunately this is already with Audyssey, so I'd need to add an outboard EQ to tweak this further. The Onkyo 709 has an EQ in it, but it is bypassed with Audyssey is engaged. If I disabled Audyssey I could make use of it. It would be fun to see what I could do with it, but I would hope Audyssey would be better
I am pondering an outboard EQ for the mains, but if this is the only area I would use it in, it would be difficult to justify adding another box.
Thanks Wayne, a BFD is within my discretionary spending range, so I'll have to ponder it. I'll play more with a flatter response (trimming the sub to -4 in the receiver does this) and make sure I prefer the house curve approach, then go from there.
--Ryan
 Reply     Post New Thread     Back to Top of Page
initial, multipurpose, opinions, results, rew, room
Bookmark and Share
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright ©2006 - 2013, Home Theater Shack, LLC.
OUR SPONSORS
Accessories4less
Audio General Inc
Chase Home Theater
Discount-Merchant
Emotiva
Epik Subwoofers
Exteris Audio
Genelec
GIK Acoustics
GR Research
HTD: Home Theater Direct
KEN KREISEL
Madisound
Marantz
MiniDSP
OPPO Digital
Power Sound Audio
RAM Electronics
Stereo Integrity
SVSound
Take Five Audio
The Audio Insider
Value Electronics
Visual Apex
The Sub Zone
OUR AFFILIATES
Abe's of Maine
Boston Acoustics A Series Speakers
Cables.com
Denon - Buy Direct. Free Shipping.
Electronics Express
Fluance
GamersGate
Harman
J&R.com
Shop for Harmony Remotes at Logitech
Shop MCM Electronics for Your Home Theater Needs
Musician's Friend Stupid Deal of the Day
Once You Know, You Newegg
Overstock.com
Parts Express: Your #1 Speaker Building Resource
Roku + Netflix = Instant Movies on your TV
Solid Signal Antenna Superstore
Sonos Wireless Music Player
SquareTrade Warranties
Vann's
vudu.com
Woot!
Zzounds
Abt Electronics
Best Buy
Butterfly Photo
Circuit City
DIRECTV
emusic.com
GameFly
HDtracks High Resolution Music Downloads
HP Computers
Klipsch
MarvelStore.com
Monoprice.com! Best quality products at the lowest price, Always!
Instantly watch from thousands of TV episodes & movies streaming from Netflix. Try Netflix for FREE!
OneCall
Buy Televisions at Panasonic.com
Paul's TV
SMS Audio
503327_Get Free Shipping At Sonic Electronix!
Sony
Super Media Store!
Velodyne
Official Shop of Warner Bros
World Wide Stereo
Epic 80 Home Theater Speakers
Search Engine Friendly URLs by vBSEO
