Set lowest frequency for sweep - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Set lowest frequency for sweep in the Subwoofer Equalization | Calibration forum; Set lowest frequency for sweep I don't even know if this is possible, but how do I set the starting frequency of a sweep in ...
Old 07-12-07, 04:54 PM   #1 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
I don't even know if this is possible, but how do I set the starting frequency of a sweep in REW?
I'd like to test my Neo3 tweeter without a crossover and sending it anything above 1.5kHz is likely to damage it. I figured out how to set the high cut, just not the low cut.
Thanks in advance,
Anthony
Old 07-12-07, 05:05 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Set lowest frequency for sweep
You can't.
It will always sweep from 0Hz to twice the upper frequency that you set..
Old 07-12-07, 05:44 PM   #3 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Ah, good to know before I blew my tweeter.
Old 07-12-07, 05:44 PM   #4 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Anthony wrote: View Post
Thanks in advance,
Anthony
Shouldn't you say below 1.5 kHz?
Old 07-14-07, 10:02 PM   #5 (Link)
Alias: Anthony
Loc: Virginia
Anthony's Avatar
User: #2921
Since: Oct 2006
Anthony is offline
Oh yeah, doh!
You HT geeks all knew what I meant
Old 07-14-07, 11:45 PM   #6 (Link)
Alias: Dan
aktiondan's Avatar
User: #6736
aktiondan is offline
I've been curious about doing the same type of measurement, maybe a future revision of REW could include a frequency adjust for the start point as well? In addition to other target filter functions besides ones for just subwoofers. I'd like to set the target filter for high-pass at 3kHz and then measure a tweeter w/ and w/o a crossover. What I have done before is just thrown in a single large cap in series with the tweeter just to block out most of the really low frequencies. A 1st order x-over will have a very small negative impact on the performance/measurement of your tweeter and yet still keep it from getting damaged by the low-frequency stuff (as long as you still keep the levels low, and measure in the near-field, 1/2" or so away from the tweeter). A 20uF cap will put you 3dB down at 1kHz, assuming your tweeter has a nominal impedance of 8 ohms, which should be enough to not damage it during a couple of quick sweeps starting at 0hz. If that doesn't seem like enough attenuation, then a 13.3uF cap would put you 3dB down right at 1.5kHz and then it's 6dB/octave from there. However I agree it would be nice to have an adjustable start frequency as well in REW for doing these kinds of tests.
Similar Threads
Can REW measure using an external sweep? lovingdvd REW Forum 3 05-20-07 02:15 PM
Amplitude at Crossover Frequency Otto REW Forum 4 05-03-07 08:14 AM
sweep or sine wave ? Bergowitz REW Forum 11 11-23-06 09:09 AM
Baseline graph 15-200Hz sweep - do I need bass traps? pclausen REW Forum 14 10-26-06 11:21 AM
measurement from external sweep? eddthompson REW Forum 2 08-31-06 08:52 AM
Mach 5 Audio
