| REW Forum Equalization using HTPCs ?Discuss Equalization using HTPCs ? in the Equalization | Calibration forum; Equalization using HTPCs ? I am trying to find some solution for equalization while using a HTPC.
Since a HTPC already is digital and ... |
Views: 768 - Replies: 15
| I am trying to find some solution for equalization while using a HTPC. Since a HTPC already is digital and all kinds of software / plugins are available.... I am wondering maybe there is some (graphic or parametric equalizer) software available which allows me to modify sound in the computer itself This will do two things: 1. Eliminate the BFD from chain 2. Enable full range equalization, possibily for all 7.1 channels If you can see where I am going....this will surely lead to improved sound quality. The problem is to find a software based equalization solution. Is there anything out there? ![]() The best option will be something which integrates a 7.1 channel parametric equalizer with REW. Now THAT will be REALLY sweet ! ![]() -Rajiv PS: We will still need REW to see what we are doing! | ||||
| | #2 | |||||
| Re: Equalization using HTPCs ? Quote:
brucek | |||||
| | #3 | ||||
| Re: Equalization using HTPCs ? Actually there are at least a couple of plugins which I am aware of. Look at fdshow and AC3Filter . Both are directshow plugins (which MCE based HTPCs can use) and have graphic equalizers inside them. They sure are limited to a few, relative wide bands and the resolution is questionable. | ||||
| | #4 | ||||
| Re: Equalization using HTPCs ? Hi There, Have a read of http://www.duffroomcorrection.com/wiki/Main_Page Its to do with Digital Room Corection and i think it is posible to use convolver as a direct show plugin - Its a slightly different method of equalisation techniques though as IIRC you create impulse response and the computer works out the filters rather than a more manual measure and tweak. Cya, Lee | ||||
| | #5 | |||||
| Re: Equalization using HTPCs ? I dont understand what "convolving" means. I have tried to understand this thing earlier too. ![]() From reading that page I understand it is able to do some sort of room equalization. I looked at the download pages. Where are the controls? ![]() Is there a page / manual which explains to a layman (or at least to a person who understands the usual tools used for equalization) what all this convolution and the process means ? Quote:
| | #6 | ||||
| Re: Equalization using HTPCs ? Hi There, I *think* the concept is that you use something like Simple Automated IR Measuring Tool to create an Impulse response of your room - The basic send out a know signal and measure what comes back idea. Then you analyse the results and calulate your filters via a pc, doing "A stereo 65536-tap filter" by hand could consiveably take a while ! - It seems you use DRC for this ? The you use Convolver with Theatertek/Zoom Player / MPC etc Simple eh ! I've yet to get round to actualy doing this....But its certainly something i want to play with. It also seems to be getting easier with time, ie the software and documentation is getting better....I remember having a look at this a year or two back !!! Cya, Lee | ||||
| | #7 | ||||
| Re: Equalization using HTPCs ? REW measures the room's impulse response, that is how it produces the frequency response plots. You can export the impulse response REW measures for use with convolver and similar packages. You can also export the impulse responses of filter setups, which is probably more useful in this instance - i.e. you would use REW to make your measurements and set up the filters to correct the response, then export the impulse response of the filters to apply it with convolver (for example). | ||||
| | #8 | |||||
| Re: Equalization using HTPCs ? Thanks for chiming in John! For use with convolver, which Equalizer should I set in the Equalizer drop down menu? Do I have to setup the filters manually or will REW do it automatically? Quote:
| | #9 | ||||
| Re: Equalization using HTPCs ? Use the Generic setting, it has the widest range of filter types and the best filter resolutions. You can automatically adjust the filters following the usual REW sequence. | ||||
| | #10 | |||||
| Re: Equalization using HTPCs ? Oh my! I just spent a few days playing with DRC (http://www.duffroomcorrection.com/wiki/Main_Page) software. This DRC software is insanely complicated! The manual is 150 pages long creating a filter file for use with the convolver is extremely complicated and involved. I'd rather use hardware graphic equalizers. Anyway, going back to REW.... Does REW will create a file which can be used straight in the convolver plugin....right? John you said: Quote:
Is there a tutorial for this somewhere? | |||||
| | #11 | ||||
| Re: Equalization using HTPCs ? | ||||
| | #13 | ||||||
brucek | ||||||
| | #14 | ||||
| Re: Equalization using HTPCs ? OK, so I entered the filter parameters manually. But when I export out the filters as a WAV....and then use in in the colvolver DSP plugin in Windows Media player....the sound does not change at all. What am I doing wrong? Is there a helpfile for using REW with convolver ? | ||||
| | #16 | ||||
| Re: Equalization using HTPCs ? I haven't used convolver myself, but there's quite a bit of info on the author's website http://convolver.sourceforge.net/index.html. You can check the REW exported impulse responses by re-importing them and viewing them in REW. You can even play them directly in media player or similar, though generally there won't be anything usefully audible in them - if you made a file of a large number of 1kHz filters with 15dB gain and very high Q (50, say) then exported that impulse response and played it you would hear the ringing of the 1kHz tone in the impulse response, just for curiosity's sake. | ||||
