Full Range Measurements with REW - What Equipment? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Full Range Measurements with REW - What Equipment? in the Subwoofer Equalization | Calibration forum; Full Range Measurements with REW - What Equipment? Hi Guys, I have had a little play around with REW using my radio shack SPL meter buts its pretty ...
Old 05-21-07, 01:43 AM   #1 (Link)
New Member
Alias: Drizt
Loc: Melbourne
User: #2147
Since: Aug 2006
Drizt is offline
Hi Guys,
I have had a little play around with REW using my radio shack SPL meter buts its pretty apparent that its not really up to the task for full range measurements.
I did a quick search for "Full Range" etc, but didn't quite find what I was after. Can you guys please tell me what equipment is necessary to make accurate full range measurements. I assume a mic pre-amp and mic would be required, but what are the ones to look at for accuracy (with price a constraint)?
I have had a mate recommend the following,
Rolls Mini-Mic Preamp, Legend Instrument Condenser Mic........with cables around $300 or less.
What do you guys think of the above suggestion?
Can you make some other suggestions for me?
Regards
Drizt
Old 05-21-07, 04:06 AM   #2 (Link)
Alias: terry
Loc: bathurst nsw australia
User: #1819
terry j is online now
Re: Full Range Measurements with REW - What Equipment?
Hi Drizt
you'll need a mic obviously, and about the cheapest is the behringer ecm 8000, around $100 here in Australia, prob less if shop around. Use the generic cal file off the shack.
Then you will need to get those measurements into the computer, so some sort of mixer with phantom power is reqd. I use the behringer xenyx 802, about $110 but shop around. With Behringer gear they usually give you a discount straight away!
mic leads, not expensive say $20 a pop, and even a mic stand from any old music store, say $50.
Still use the R/S meter to set the sound level (I don't usualy bother with it, as long as I have a good signal I just tell it it is 75 db and off I go).
Off hand can't think of anything else, good to see another aussie, hope they keep coming ha ha.
see ya
Old 05-21-07, 04:24 AM   #3 (Link)
New Member
Alias: Drizt
Loc: Melbourne
User: #2147
Since: Aug 2006
Drizt is offline
Thanks very much Terry J, good to see a familiar face around
Just curious, how is the behringer gear regarded in terms of accuracy?
Old 05-21-07, 06:01 AM   #4 (Link)
Alias: terry
User: #1819
Ultimately I suppose it is not as accurate as some (most?) but then again, it all depends on what level of accuracy you need.
It is certainly more accurate than the R/S meter (isn't it?? ha ha) and gets the job done.
If you are using it to get an idea of what you mains are like FR wise (else you wouldn't need full range measurements) who cares if it is one or two db out here and there, as you won't be doing anything to change it anyway!
If you use it from your seat then it matters even less that it might be out a bit, and a mic costing ten times as much will not give you any more information in that situation anyway.
Drizt, I can see you are new here and so probably don't know the procedure and what happens next.
What happens next is that someone comes along and corrects everything I just said ha ha, because as you will find there are a lot of very knowledgable people here and they are very helpful too! (well maybe not on this post, as it is pretty straight forward.) Browse around, there is a lot to be learnt here.
Old 05-21-07, 06:13 AM   #5 (Link)
New Member
Alias: Drizt
Loc: Melbourne
User: #2147
Since: Aug 2006
Drizt is offline
Thanks Terry J.
If I find that my tweeter is running hot then I can make a change to rectify it
Old 05-21-07, 08:01 AM   #6 (Link)
Alias: alan monro
Loc: Melbourne Australia
alan monro's Avatar
User: #465
alan monro is offline
Drizt wrote: View Post
Thanks Terry J.
YES,.Give your bird tons of water and shift the cage to the cool outside Seriously , How do you know if your tweeter is running to hot?? . Have you felt it and it appears hot ? . I can imagine if one overdrives a speaker it may get warm before it blows out , but not get hot to touch. If the tweeter is getting hot replace it with a more powerfull unit . Kind regards Alan.
Old 05-21-07, 02:35 PM   #7 (Link)
Alias: Bernard
User: #36
Glyptoron is offline
Hi Drizt,
I'm using this german kit. It's a very good deal and the price is around 300 AUD including postage.
http://www.content.ibf-acoustic.com/...products_id=35
It's the one recommended for ETF5.
You can ask any question to Mr Frank, you'll get an answer.
Cheers.
Bernard
Old 05-21-07, 02:58 PM   #8 (Link)
Alias: brucek
User: #6
brucek is offline
Looks like a nice mic and pre-amp. Did you get a calibration file with it?
Old 05-21-07, 03:16 PM   #9 (Link)
Alias: Bernard
User: #36
Hi Bruce,
The calibration file is included in the kit on a 3.5" diskette.
It's not a "standard" calibration file. It's the appropriate file of the mic you purchase.
Indeed, it's a good mic and the pre-amp works with a 9 V battery. No noise from AC current.
Regards.
Bernard
Old 05-21-07, 03:36 PM   #10 (Link)
Alias: brucek
User: #6
brucek is offline
You can easily create a meter.cal file from it that would work with REW. The REW cal files are simple txt based.
Old 05-21-07, 04:16 PM   #11 (Link)
New Member
Alias: Drizt
Loc: Melbourne
User: #2147
Since: Aug 2006
Drizt is offline
alan monro wrote: View Post
Hot is a figure of speach.... if the tweeter is running higher dB then my mid/bass driver then its running 'hot' ... nothing to do with temperature.
Old 05-21-07, 07:29 PM   #12 (Link)
Alias: alan monro
alan monro's Avatar
User: #465
Havn't heard that one before,
Old 07-01-07, 09:11 PM   #13 (Link)
New Member
Alias: Drizt
Loc: Melbourne
User: #2147
Since: Aug 2006
Drizt is offline
Hi Guys, I'm after a bit of help with regards to mic preamp suggestions. Thanks already to Terry J for his suggestions.
Behringer MIC800 Mini Mic Preamp
http://www.allansmusic.com.au/defaul...uctCode=MIC800
Behringer 802 Xenyx Series 8 Input 2 Mic XLR Mixer [ON RANGE]*
http://www.allansmusic.com.au/defaul...tCode=XENYX802
Just wondering if either of these will do, or is one better than the other for my needs. Again sorry for the noobie question.
Regards
Drizt
Old 07-01-07, 10:06 PM   #14 (Link)
Alias: brucek
User: #6
brucek is offline
Go with the 802 - it's the one most people use. The MIC800 has a low cut filter that can't be defeated. You want the preamp to be as flat as possible....
Old 07-02-07, 12:01 AM   #15 (Link)
New Member
Alias: Drizt
Loc: Melbourne
User: #2147
Since: Aug 2006
Drizt is offline
brucek wrote: View Post
Thank you for explaining. Ill go with that one.
Old 07-21-07, 03:11 PM   #16 (Link)
Alias: Ray
Loc: New Jersey
User: #6263
raylock is offline
I believe that I saw a picture of this unit with the proper settings to be used with the REW somewhere but I can't find it again. Does anyone know where this is? Thanks
Ray
Old 07-21-07, 06:24 PM   #17 (Link)
Alias: brucek
User: #6
brucek is offline
You mean this?
Old 07-21-07, 07:31 PM   #18 (Link)
Alias: Ray
Loc: New Jersey
User: #6263
raylock is offline
Yes. Thanks brucek.
Ray
Old 07-21-07, 11:32 PM   #19 (Link)
Alias: Dan
aktiondan's Avatar
User: #6736
aktiondan is offline
Drizt, I plan on doing full-range measurements with the aforementioned pieces of equipment as well. In fact, I just received my ECM8000 and Xenyx 802 mixer this weekend and have been having quite a bit of fun playing around with it. I haven't had the mic calibrated, but from the couple of plots I've done so far, I'm really happy with the setup. Much better than the RS meter for sure. And the cost is just about right too!
Old 07-21-07, 11:50 PM   #20 (Link)
New Member
Alias: Drizt
Loc: Melbourne
User: #2147
Since: Aug 2006
Drizt is offline
You mean this?
Cheers, I found that one before and it helped a lot
Got mine all up and running and seems to work well. Thanks for all the help guys.
Similar Threads
4" full range Speakers BoomieMCT DIY Speakers 25 02-26-08 05:21 AM
Some Q's on full range speakers BoomieMCT DIY Speakers 13 10-11-07 05:05 PM
Full Range CD Danny Music and DVD Concerts 2 02-10-07 08:21 PM
accuracy of REW for full range measurements? terry j REW Forum 8 11-18-06 05:00 AM
REW Full-Range Features? Longfellowe REW Forum 4 06-02-06 03:30 AM
Mach 5 Audio
