Equalization using HTPCs ? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
REW Forum
Discuss Equalization using HTPCs ? in the Subwoofer Equalization | Calibration forum; Equalization using HTPCs ? I am trying to find some solution for equalization while using a HTPC. Since a HTPC already is digital and ...
Old 07-18-07, 10:08 AM   #1 (Link)
Alias: Rajiv
Loc: Woodbridge, VA
User: #3440
Since: Oct 2006
rajdude is offline
Lightbulb Equalization using HTPCs ?
Since a HTPC already is digital and all kinds of software / plugins are available.... I am wondering maybe there is some (graphic or parametric equalizer) software available which allows me to modify sound in the computer itself
This will do two things:
1. Eliminate the BFD from chain
2. Enable full range equalization, possibily for all 7.1 channels
If you can see where I am going....this will surely lead to improved sound quality.
The problem is to find a software based equalization solution. Is there anything out there?
The best option will be something which integrates a 7.1 channel parametric equalizer with REW. Now THAT will be REALLY sweet !
-Rajiv
PS: We will still need REW to see what we are doing!
Old 07-18-07, 10:44 AM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Equalization using HTPCs ?
I'm not aware of any plug-in that allows that to be accomplished. But you're certainly not the first member to think of it....
Old 07-18-07, 10:54 AM   #3 (Link)
Alias: Rajiv
Loc: Woodbridge, VA
User: #3440
Since: Oct 2006
rajdude is offline
Actually there are at least a couple of plugins which I am aware of.
Look at fdshow and AC3Filter .
Both are directshow plugins (which MCE based HTPCs can use) and have graphic equalizers inside them. They sure are limited to a few, relative wide bands and the resolution is questionable.
brucek wrote: View Post
Old 07-18-07, 12:25 PM   #4 (Link)
Alias: Lee
Loc: Huntingdon, Cambs. UK
User: #362
Alaric is offline
Hi There,
Have a read of http://www.duffroomcorrection.com/wiki/Main_Page
Its to do with Digital Room Corection and i think it is posible to use convolver as a direct show plugin - Its a slightly different method of equalisation techniques though as IIRC you create impulse response and the computer works out the filters rather than a more manual measure and tweak.
Cya,
Lee
Old 07-18-07, 01:38 PM   #5 (Link)
Alias: Rajiv
Loc: Woodbridge, VA
User: #3440
Since: Oct 2006
rajdude is offline
I dont understand what "convolving" means. I have tried to understand this thing earlier too.
From reading that page I understand it is able to do some sort of room equalization. I looked at the download pages.
Where are the controls?
Is there a page / manual which explains to a layman (or at least to a person who understands the usual tools used for equalization) what all this convolution and the process means ?
Alaric wrote: View Post
Hi There,
Cya,
Lee
Old 07-19-07, 06:10 AM   #6 (Link)
Alias: Lee
User: #362
Alaric is offline
Hi There,
I *think* the concept is that you use something like Simple Automated IR Measuring Tool to create an Impulse response of your room - The basic send out a know signal and measure what comes back idea.
Then you analyse the results and calulate your filters via a pc, doing "A stereo 65536-tap filter" by hand could consiveably take a while ! - It seems you use DRC for this ?
The you use Convolver with Theatertek/Zoom Player / MPC etc
Simple eh !
I've yet to get round to actualy doing this....But its certainly something i want to play with. It also seems to be getting easier with time, ie the software and documentation is getting better....I remember having a look at this a year or two back !!!
Cya,
Lee
Old 07-19-07, 08:20 AM   #7 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
REW measures the room's impulse response, that is how it produces the frequency response plots. You can export the impulse response REW measures for use with convolver and similar packages. You can also export the impulse responses of filter setups, which is probably more useful in this instance - i.e. you would use REW to make your measurements and set up the filters to correct the response, then export the impulse response of the filters to apply it with convolver (for example).
Old 07-19-07, 10:08 AM   #8 (Link)
Alias: Rajiv
Loc: Woodbridge, VA
User: #3440
Since: Oct 2006
rajdude is offline
Thanks for chiming in John!
For use with convolver, which Equalizer should I set in the Equalizer drop down menu?
Do I have to setup the filters manually or will REW do it automatically?
JohnM wrote: View Post
Old 07-19-07, 10:14 AM   #9 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Use the Generic setting, it has the widest range of filter types and the best filter resolutions. You can automatically adjust the filters following the usual REW sequence.
Old 07-23-07, 07:31 AM   #10 (Link)
Alias: Rajiv
Loc: Woodbridge, VA
User: #3440
Since: Oct 2006
rajdude is offline
Oh my! I just spent a few days playing with DRC (http://www.duffroomcorrection.com/wiki/Main_Page) software.
This DRC software is insanely complicated! The manual is 150 pages long creating a filter file for use with the convolver is extremely complicated and involved.
I'd rather use hardware graphic equalizers.
Anyway, going back to REW....
Does REW will create a file which can be used straight in the convolver plugin....right?
Sorry but I am a newbie...what is the "usual REW sequence" ?
Is there a tutorial for this somewhere?
Old 07-23-07, 07:37 AM   #11 (Link)
Alias: Rajiv
Loc: Woodbridge, VA
User: #3440
Since: Oct 2006
rajdude is offline
Ok I found the helpfile at
http://www.hometheatershack.com/room...tml/index.html
sorry !
Old 07-23-07, 07:50 AM   #12 (Link)
Alias: Rajiv
Loc: Woodbridge, VA
User: #3440
Since: Oct 2006
rajdude is offline
Ok,
How do I assign filters for full range correction?
The find peaks works only upto 500 Hz.
Even there it keeps says "No peaks found"
Old 07-23-07, 08:33 AM   #13 (Link)
Alias: brucek
User: #6
brucek is offline
You would enter filters manually into the EQ Filters panel where you can tweak the automatic filters suggested by REW and also you may enter values for full range. You also need to enter any filters with gain manually. Note that the results of the filters entered manually or automatically are dynamically reflected on the graph panel response.
It will say that if it doesn't find any suitable peaks above the target line you have set.
Old 07-23-07, 08:38 AM   #14 (Link)
Alias: Rajiv
Loc: Woodbridge, VA
User: #3440
Since: Oct 2006
rajdude is offline
OK,
so I entered the filter parameters manually. But when I export out the filters as a WAV....and then use in in the colvolver DSP plugin in Windows Media player....the sound does not change at all.
What am I doing wrong?
Is there a helpfile for using REW with convolver ?
Old 07-23-07, 10:48 AM   #15 (Link)
Alias: brucek
User: #6
brucek is offline
No, sorry. Maybe JohnM can help with this.......
Old 07-23-07, 03:53 PM   #16 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
I haven't used convolver myself, but there's quite a bit of info on the author's website http://convolver.sourceforge.net/index.html. You can check the REW exported impulse responses by re-importing them and viewing them in REW. You can even play them directly in media player or similar, though generally there won't be anything usefully audible in them - if you made a file of a large number of 1kHz filters with 15dB gain and very high Q (50, say) then exported that impulse response and played it you would hear the ringing of the 1kHz tone in the impulse response, just for curiosity's sake.
Similar Threads
BFD for full-range room equalization gsmollin Home Theater Components 18 05-13-06 11:34 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133
