| REW Forum Guide to using REW with Convolver...Discuss Guide to using REW with Convolver... in the Subwoofer Equalization | Calibration forum; Guide to using REW with Convolver... (under construction) I looked everywhere but could not find a tutorial or helpfile which describes how to use REW with ... |
| | #1 (Link) | |||||
| Guide to using REW with Convolver... (under construction) I looked everywhere but could not find a tutorial or helpfile which describes how to use REW with Convolver. Hence I thought I will start a thread. First: What is convolver? Convolver is an Windows application which can be used for Digital Room Correction. It can be used as a plugin for Windows Media player (and other apps). Full details are here. A long convolver thread is here. Second: Where does REW fit into the picture? REW measures the room's impulse response. That is how it produces the frequency response plots. Then you can (automatically or manuall) setup the filters. After this you can export the impulse responses of filter setups Step by step guide:
That is it ! Until here the setup is simple. But for best sound quality you have use multiple files for multiple channels. I will quote jrpavel’s post on AVSForum here: http://www.avsforum.com/avs-vb/showt...&&#post6939704 Quote:
It will allow a pair of responses to be exported as a stereo WAV. This can be used on convolver for 2 channel audio (stereo) I will add More later... Others, please correct me if I am wrong and add tips and questions in this thread. Here are some more links for further info on this topic: HTPC and Digital Room Correction : http://archive2.avsforum.com/avs-vb/...d.php?t=445559 Step by Step guide for using DRC: http://www.duffroomcorrection.com/im...Guide_v1.0.pdf In the search for the best parametric eq software for the HTPC... http://archive2.avsforum.com/avs-vb/...d.php?t=283878 Last edited by rajdude : 07-24-07 at 08:49 AM. Reason: added info | |||||
| | #3 (Link) | |||
| Re: Guide to using REW with Convolver... Looks like I broke the export at some point - the list of filter sets for export only contains previous measurements and not the current measurement. If you have no measurements you can export "current settings", if you have more than 1 you can export the settings of the filters for any previous tab but not the latest one. If you only have one measurement you get an empty list. Sorry about that, I'll fix it for the next release. | |||
| | #4 (Link) | |||
| Re: Guide to using REW with Convolver... Added later..... it works! Ignore this post! The problem was that in REW I had opened up the last measurement and applying my filters to it....but when exporting REW was presenting me the earlier measurements....which had no filters ! Stupid me.....just wasted a few hours on this ! I suck ! John, Thanks ! You are right....with more measurements in REW I am able to export.......just like you described above. But I am having another issue... When I export the "Filter impulse response as WAV" and use it in convolver....it does nothing... I used a RTA with pink noise to find out that. What's up? Also is there is nothing in the exported WAV. I mean when I try to play that WAV...I hear nothing. Whereas I can download some sample IR WAVs here : http://convolver.sourceforge.net/links.html When I play them I hear something. Also...... they do work in convolver. Last edited by rajdude : 07-24-07 at 11:02 AM. Reason: added more info | |||
| | #5 (Link) | |||
| Re: Guide to using REW with Convolver... Ignore this post....see above why. Here is a test filter which I am having trouble with.... ---------------------------------------------------------- Filter Settings file Room EQ V4.00 Dated: Jul 24, 2007 10:13:25 AM Notes: Equaliser: Generic Jul 23 12:06:10 Full range Target level: 50.0dB Filter 1: ON PK Fc 50.0Hz Gain 16.0dB Q 0.493 Filter 2: ON PK Fc 2,987.5Hz Gain -26.0dB Q 0.832 Filter 3: ON None Filter 4: ON None Filter 5: ON None Filter 6: ON None Filter 7: ON None Filter 8: ON None Filter 9: ON None Filter 10: ON None Filter 11: ON None Filter 12: ON None Filter 13: ON None Filter 14: ON None Filter 15: ON None Filter 16: ON None Filter 17: ON None Filter 18: ON None Filter 19: ON None Filter 20: ON None ------------------------------------ The WAV exported from REW is blank. (see attachment) Why? ![]() Someone please help me ! ![]() Last edited by rajdude : 07-24-07 at 11:03 AM. | |||
| | #6 (Link) | |||
| Re: Guide to using REW with Convolver... Anyway....I just got it working! It works amazingly good ! And it is **** simple to do....MUCH MUCH better than using DRC or the long ..lengthy procedure. You just tweak your filters and export a file to convolver. and thats it ! Now I have to figure out how to make it work in a Home theater with 7.1 channels of audio. Thanks a million John! your REW application rocks, big time ! [It would be nice if you can correct that export issue....] | |||
| | #7 (Link) | ||||
| Re: Guide to using REW with Convolver... Quote:
and I fixed the export bug last night so the next release will sort that out. | ||||
| | #8 (Link) | |||
| Re: Guide to using REW with Convolver... was always curious about convolver etc etc, but it always made my eyes glaze over ha ha. The links above led me to read (well, started anyway-not finished yet) the threads on the avs forum on REW and on DRC. The one on DRC has been archived, which I guess only shows how old it is, the trouble is the guy who started that thread evidently did a big write up on how to use the drc, but the link is no longer active. SOooo, has that write-up been moved somewhere and is it still available?? I only hope that if it is it is written in such a way that an idiot like me can fumble my way through it. Rajdude, I would assume that the level of computer knowledge required to successfully get this type of thing up and running is more than required to nut out REW, what is the relative levels of difficulty in your estimation??(only to give me some sort of idea, if the answer is "WWAAAYYY harder dude" then I probably wouldn't even try!!) | |||
| Thread Tools | |
Similar Threads | ||||
| Handy placement guide | Hitmaker | Home Theater Design and Construction | 3 | 06-11-07 01:04 AM |
| Reference Earphones with REW and Convolver | Ayreonaut | REW Forum | 3 | 03-02-07 08:43 AM |
| An unbiased guide to buying a plasma | HDBeat | Home Theater, Audio and Video News | 0 | 08-22-06 11:43 PM |
| thanks for the guide! | cyberbri | BFD Forum | 2 | 08-08-06 03:58 PM |
| Guide to Sub box Design | Danny | DIY Subwoofers | 12 | 05-13-06 10:48 AM |
