Average House Curve - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Average House Curve
Discuss Average House Curve in the Subwoofer Equalization | Calibration forum; Average House Curve I was wondering if those of you with House Curves could post your curve. Basically I want to see if ...
Old 06-04-07, 02:38 PM   #1 (Link)
Alias: Jerm357
Loc: Detroit
Jerm357's Avatar
User: #717
Jerm357 is offline
Average House Curve
I was wondering if those of you with House Curves could post your curve. Basically I want to see if we can figure out what the average House Curve is that people like. If you could just post your House curve file numbers like this......
30hz +10db
80hz 0db
This curve is 10db higher at 30hz than it is at 80hz. I just think it would be nice to have a list of curves that people like so others could try them out.
Old 06-05-07, 01:14 AM   #2 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
Re: Average House Curve
80hz 0
20hz +25db
no, that is not a typo
Old 06-05-07, 07:12 AM   #3 (Link)
Alias: brucek
User: #6
brucek is offline
20hz +25db
I guess you understand the negative effects of that much gain?
Old 06-05-07, 09:57 AM   #4 (Link)
Alias: Edward
Loc: Brampton ON, Canada
User: #8188
Since: Apr 2007
clubfoot is offline
Hakka wrote: View Post
80hz 0
20hz +25db
Holly smoke, I think I would crack my foundation!
Old 06-05-07, 06:51 PM   #5 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
C’mon, people. All he’s saying is that his output at 20 Hz is 25 dB greater than at 80 Hz. That doesn’t mean he EQ’d 20 Hz up that high.
That said – it’s a grossly severe house curve differential! I don’t think even a car would need one that steep...
Old 06-05-07, 07:23 PM   #6 (Link)
Alias: brucek
User: #6
brucek is offline
How did he get meet the target then?
Old 06-05-07, 09:24 PM   #7 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
No boost is used on that curve, just cuts. I know its not reccommended but it sounds good to me. I have tried dialing it back a bit but I feel like something is missing.
I didn't use the housecurve feature in REW, I just shaped my curve manually.
Hakka.
Old 06-06-07, 06:42 AM   #8 (Link)
Alias: Edward
User: #8188
Since: Apr 2007
clubfoot is offline
Hakka.
Do you set your spl ref level before or after inputing the house curve?
Old 06-06-07, 12:39 PM   #9 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
brucek wrote: View Post
Hmm, let me count the ways! If the room is small enough, a lot of it could come “free” via cabin gain. Corner placement will typically get more low-end boost vs. say, middle-of-a-wall placement. And doubling subs like Hakka has done of course gets more of everything than a single one.
Of course, there is the electronic means, boosting with an EQ, or as Hakka mentioned, cutting upper frequencies to accomplish the same thing. The sub amp and drivers “see” either method the same way as far as the demands placed on them.
We have to keep in mind that it’s all relative to the capabilities of the subwoofer system in question. For instance, if someone has four 18” subs with 4000 watts of power divided between them, all located in a 1200 cu. ft. room, even an electronic 25 dB boost would be nothing more than a hiccup. An extreme example, sure, but you get the idea.
All of which is why I don’t necessarily break a sweat when I see someone saying they’ve “boosted” 20 Hz by 25 dB. If their system weren’t capable of handling it, they would have known in the first two seconds!
Old 06-06-07, 10:19 PM   #10 (Link)
Alias: Edward
User: #8188
Since: Apr 2007
clubfoot is offline
I see, 20Hz was not touched, just all the other frequencies were lowered by 25db. So the main frequency load on the sub amp is 20Hz. The main thing is that you like what you listen to.
Old 06-07-07, 02:07 AM   #11 (Link)
Alias: Hakka
Loc: australia
User: #2510
Since: Sep 2006
Hakka is offline
My room is very small, the raw curve with no eq applied still has the same basic shape, 20hz is higher than the rest, the BFD is just taking care of some humps above 50hz and cutting 60-100hz a bit. I don't have any +/- 25db filters, I think a 12db cut is the biggest. I don't have my graphs here at the moment.
I used REW to balance the SPL of the subs vs mains. I did a sweep of my mains and a sweep of the subs and set the levels so that 90 -100hz from the subs is equal SPL to the average level of the mains.
Hakka.
Old 06-07-07, 01:57 PM   #12 (Link)
Alias: Jerm357
Loc: Detroit
Jerm357's Avatar
User: #717
Jerm357 is offline
Does any one else have a HouseCurve to list?
Old 06-07-07, 02:09 PM   #13 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is online now
Hi Jerm,
IIRC, I'm about 6 dB hot at 20 Hz and 0 at 60.
20 +6
60 0
For 2 channel listening, I crush the signal at 40 Hz, and am a little hot at 20.
So something like:
20 +3
40 -60
And then I integrated the mains and sub with that curve until things looked and sounded decent.
I'm sure someone will post that I'm all screwed up, but that's the way it is at the moment.
-- Otto
Old 06-18-07, 02:09 AM   #14 (Link)
Alias: daxie
User: #4496
Since: Nov 2006
daxie is offline
80hz 0
20hz +25db
16Hz + 18dB
****, I though mine was severe...
But planning on tempering it, in my small room it's just too boomy
Old 06-18-07, 04:47 AM   #15 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
The human ear's sensitivity varies at different frequencies depends on listening levels. (not to mention age/history related hearing loss at the frequency extremes)
So one really ought to have a range of house curves depending on one's average listening levels at any particular moment. No two subwoofers or rooms offer similar response curves or extension without modification.
Check out Equal Loudness curves, Fletcher Munson etc. What sounds right at 70dB may not sound right at a steady 90dB. If the bass sounds right to you at both levels then that's all that matters. It's your system and your ears.
Old 06-18-07, 06:40 AM   #16 (Link)
New Member
Alias: neal
User: #5837
Since: Jan 2007
neal is offline
After allot of playing around I found that
80 +0
20 +12
Sounds good for movies with my SVS sub.
The thing that I find funny is my wife actually likes a bit more on the low end.
Old 06-19-07, 05:58 AM   #17 (Link)
Alias: Jim
Loc: Wetumpka
User: #630
JimP is offline
Wayne,
In your writeup about house curve, you mentioned raising the spl of 32 hz so that to your ear (in your specific room) its perceived as loud as 80hz (or 100hz). Then creating a curve around that.
Is there a convenient way of running a wave file of rapidly alternating 32 and 80hz signals so that one can make this comparison?
Old 06-19-07, 07:16 AM   #18 (Link)
Alias: brucek
User: #6
brucek is offline
Use the signal generator in REW.......
You could also make a CD with two tones of 32Hz and 100Hz switching back and forth on alternate tracks and play the CD....
Old 06-20-07, 03:08 PM   #19 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
Jerm357 wrote: View Post
Hi Jerm. Using
80:0
30:10
Here is the FR at LP
Old 07-05-07, 11:08 AM   #20 (Link)
Moderator Emeritus
Alias: Naut
Loc: Richmond, VA
Ayreonaut's Avatar
User: #203
Ayreonaut is offline
20 Hz, +10 dB
63 Hz, +0 dB
http://www.hometheatershack.com/foru...e-options.html
We are the Shack. Existence as you know it is over.
We will add your biological and technological distinctiveness to our own.
You will be mapped. Resistance is futile.
Old 07-06-07, 09:09 PM   #21 (Link)
Alias: norpus
Loc: Melbourne
norpus's Avatar
User: #3037
Since: Oct 2006
norpus is offline
My house curves more than normal...
depends how loud I play the subs as to the size of the curves in the walls and floors hahaha
Someone once said it was like surfing at my place - the waves on the floor that is
In less jest, the freq response (sub only) after using filters in the the behringer fbq2496 was fairly flat - as seen below
We couldn't adjust anything below 20, and the crossover to the mains is 60Hz
I now have 2 infloor IB subs - the 100% coupling to the structure creates quite a tactile effect
Cheers
Norpus
Old 07-07-07, 05:46 AM   #22 (Link)
Alias: brucek
User: #6
brucek is offline
Norpus,
Generally, to mathematically comply with the logarithmic nature that is representative of human hearing, we use octaves to measure and graph subs. You've done such a great job of creating a very flat response, so it likely won't make much difference in your case.
On our downloads page, we have some predone excel graphs that result in a logarithmic graph by plotting octave scales. You might take a look at those and see if they would work for you, depending on the meter you're using.
You might also take a look at the free software REW that increases the accuracy of your measurements. It makes setting up the BFD a lot easier. It just takes a PC, meter, and some cables. We know you have a PC and meter already.
Old 07-07-07, 07:02 AM   #23 (Link)
Alias: terry
Loc: bathurst nsw australia
User: #1819
terry j is online now
it never ceases to amaze me how patient you are Bruce k, NEVER GET UPSET BUT ALWAYs the gentle push towards the help files or whatever...well done.
I've had the pleasure of 'surfing the waving floor' at Norpus' place, and recommend an experience like that to all who can avail themselves of it!!! What I will say here tho, Norps may not be fully up with REW but all around him are many who are, and have used the fabulous resource that is REW (and the HTS) to fine tune the listening experience that is on offer at 'chez norps'.
Having said that, not sure why he didn't post his response in REW format, maybe because that is on other peoples computers??
Old 07-07-07, 07:58 AM   #24 (Link)
Alias: brucek
User: #6
brucek is offline
Thanks terry. Yeah, norpus could certainly use REW to simply graph the response he measured by hand (no cables required). He would only need to create a simple notebook text (.txt) file consisting of his measurements and results and Import that measurement into REW. It will then plot the results that he can overlay with various targets etc...
Old 07-07-07, 08:55 AM   #25 (Link)
Alias: terry
User: #1819
ahh, cool. Bit like creating a house curve, type in a few figures and bob's your uncle.
As long as you got the validation I (and many others on the shack) was giving to you then that's fine.
In fact, all the moderators here do a fantastic job.
Must have had a few too many beers tonight, going all girly touchy feely. Must knock it off.
