| REW Forum help with using REWDiscuss help with using REW in the Subwoofer Equalization | Calibration forum; help with using REW Hi,
I have installed REW and read through the help files,
I have no SPL meter, can I do it ... |
| | #1 (Link) | |||
| help with using REW Hi, I have installed REW and read through the help files, I have no SPL meter, can I do it without? When I try to calibrate I get the following message; Please select the audio input for the SPL meter. Can anyone help? Thanks | |||
| | #2 (Link) | ||||
| Re: help with using REW Quote:
To calibrate the soundcard you must first connect a cable from line-out to line-in and select the correct channel (i.e. right) and also select the correct Soundcard device and input output you're using. Select these on the Settings screen under the Soundcard tab. See the pic below.. Check Levelsxxxxx clear.jpg brucek | ||||
| | #3 (Link) | |||
| Re: help with using REW Thanks for your response, I'll try to find an spl meter. As for selecting the correct soundcard device input/output, my card doesn't appear in the list, only the default input is possible, I think the app. doesn't see my card.. | |||
| | #4 (Link) | ||||
Are you perhaps running another application that uses the audio input output, and has exclusive control over the soundcard? brucek | ||||
