Creative X-Fi & Vista? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Creative X-Fi & Vista? in the Subwoofer Equalization | Calibration forum; Creative X-Fi & Vista? I have been away from REW for a while and thought I would try using my new HTPC with REW. ...
Old 07-27-07, 06:11 PM   #1 (Link)
Alias: Adam
Loc: Cambridgeshire UK
AngelEyes's Avatar
User: #3816
Since: Nov 2006
AngelEyes is offline
I have been away from REW for a while and thought I would try using my new HTPC with REW. I have an internal Creative X-FI Extreme card running on Vista x86.
I get the usual feedback loop problem when I try an calibrate the card but I can't for the live of my work out how to turn off monitoring. There doesn't seem to be an option to do this with the limited software that works in Vista.
Can anyone offer some advice?
Thanks
Adam
Old 07-28-07, 06:06 AM   #2 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Re: Creative X-Fi & Vista?
Might want to check Creative's site, i think they released an updated driver and audio console pack for the Xtreme audio card a week or so ago.
Old 07-28-07, 06:14 AM   #3 (Link)
Alias: Adam
AngelEyes's Avatar
User: #3816
Since: Nov 2006
Thanks John.
I am not sure which piece of software is relevant but I will download them all and find out. If i get it working I will try and document the procedure in case someone else has the same issue... assuming I actually know what I am doing
Adam
Similar Threads
Creative Labs lcaillo Manufacturer and Vendor Reference Information 0 05-24-07 07:25 AM
help with creative mp3 soundblaster setup pete6737 REW Forum 10 10-15-06 07:57 AM
Creative MP3+ discontinued??? Anthony REW Forum 5 10-06-06 10:26 AM
Creative Xmods Your iPod Wayde Home Theater, Audio and Video News 0 10-04-06 10:40 AM
Creative MP3+ problem w8liftr REW Forum 9 06-26-06 01:08 PM
Mach 5 Audio
