| REW Forum My initial resultsDiscuss My initial results in the Subwoofer Equalization | Calibration forum; My initial results Sorry not using the REW software yet but planning too, so here is a initial result using the available excel ... |
| | #1 (Link) | |||
| My initial results Sorry not using the REW software yet but planning too, so here is a initial result using the available excel version: I have some issues as you can see. This is only eq'ing my front sub which is in cabinetry (I'll get a photo up soon on that). The cabinet is eating up a lot of the sound so I'm working on that and hope I can come up with a good solution. I have a rear sub which helps tremendously for movie environments. But I don't like it when watching concerts as I would rather the bass come from the front of the stage. Mike | |||
| | #2 (Link) | |||
| | Re: My initial results Yeah... it looks like you got a whole around 60hz or so. Moving it to the front of the room might very well help. You can click on the graph and copy/save it to your hard drive somewhere. Then up load it as an attachment and insert it into your post. The graph will be much bigger and easier to read then. If you need help let me know. | |||
| | #5 (Link) | |||
| Re: My initial results LOL, was just looking at it... Got two Macintosh computers in the house, no Windows comps! Need to borrow a laptop for a week from somebody! Mike Denon AVR3805, Denon 3910, BFD1124, Axiom M60 fronts, QS8 rears, VP150 center, M&K sub, Yamaha sub in back. | |||
| | #8 (Link) | ||||
| Re: My initial results Quote:
You may well be able to run REW on you Mac. I just started playing with REW recently and have it running perfectly on my PowerBook G4 using the laptop's line in and out. This is with the Java 5.0 release 4 from Apple installed. I also have it running well under Windows XP Media Center on my MacBook using Parallels. Works fine there too. However, on the MacBook, I can't run quite run it under OSX's Java 5.0. The program locks up one CPU core to 100% and becomes unresponsive soon after doing an automated measurement. (My suspicion is one of the supplied REW modules was PowerPC specific and bombs out on an Intel based Mac. So... If you have a PowerPC based Mac, you'll probably be fine running under OSX. If you are on a MacTel machine, the current Mac/Linux release isn't stable but you can run it using Windows on your Mac. At any rate, REW is a very nice and easy to use program. It's a great companion to ETF and I think easier to use. | ||||
| | #9 (Link) | |||
| | Re: My initial results Hello Guy... good to see ya here. Sure hope you stick around... also looking forward to a HD AVIA from Ovation. This is good to know that you got REW working on a Mac... seems like this has been a troublesome issue for a lot of people. The Java 5.0 from Apple might be the key you think? | |||
| | #10 (Link) | |||
| Re: My initial results I think Guy was trying to say it's that the program needs to be updated to work on Intel. Although that seems strange unless there are JNI classes in REW. I used REW on my Dual G5 PowerMac just fine, but didn't do any measurements because that computer is upstairs and I didn't bother to move it downstairs. I'm also using Java 1.5 (5.0). | |||
| | #11 (Link) | |||
| Re: My initial results REW doesn't use any native routines, only stuff from the Java Runtime Envrionment. It does tend to crash on Macs with an exception inside Apple's JRE, I know several REW users have sent Apple their crash dumps so hopefully this will eventually get resolved. | |||
| | #12 (Link) | |||
| Re: My initial results So no native code segments. not even for the low level I/O?..... Might be something with the Java implementation that Apple has done for the Intel Mac's. It seems to work fine on my PowerPC machine. At least it runs fine on an Intel Mac if one is running Windows and Parallels so one isn't dead in the water. | |||
| | #14 (Link) | ||||
My servo 15 is central along our front wall directly under our screen facing towards the viewing position. Last night I set REW to output a 50Hz sound (sub only) and tried adjusting the phase, no joy. But when I stood up and went walkabout's around the room I noticed dramatic changes in spl, it appears that our seating position is bang in the middle of the 'hole', moving a couple of feet nearer or further away makes all the difference. Problem I've got is my seating position is perfect for the size of my screen. Using REW I tried to flatten my response but the only way I could achieve this was to add gain to the 40-60Hz region, the dip was about 30dB too much to relay on just cutting back the peaks. I've now lost all headroom around 40-60Hz and it sounds dreedfull. Do you think it's worth having the the sub facing the wall pointing away rather than at me? a bit like a cars sub? Mike have you managed to get REW working yet?? Kit: VDC Marquee 8110+, Crystalio 1, Da-lite Cinema Vision fixed screen, HTPC, Denon DVD2900-SDI, Roksan TT, TiVo, EAD processor, Sunfire Cinema Grand Signature amp, Totem Mani-II Ref fronts, rears & centre, Paradigm Servo-15/BFD/REW, Sony ES Dab tuner, Pronto. | ||||
| | #15 (Link) | ||||
brucek | ||||
| | #16 (Link) | ||||
| | #17 (Link) | |||
| Re: My initial results Thought you were going to say that, problem I've got is the cabinet. After all the time and effort I spent building it to accommodate the sub and centre speaker It seams such a waist Plus the cabinet was part of my WAF programme! Oh well, the chain saw it is then! Kit: VDC Marquee 8110+, Crystalio 1, Da-lite Cinema Vision fixed screen, HTPC, Denon DVD2900-SDI, Roksan TT, TiVo, EAD processor, Sunfire Cinema Grand Signature amp, Totem Mani-II Ref fronts, rears & centre, Paradigm Servo-15/BFD/REW, Sony ES Dab tuner, Pronto. | |||
| | #18 (Link) | |||
| Re: My initial results Moved the sofa (couch) about 12" further back last night and it has made a difference but still not enough! The wife is out tomorrow night and the plan is to substitute the round table under the table cloth (to the right in the above picture) with the sub, do you think she'll notice...... I'll post some graphs of, as it was, sofa 12" back and then sub in disguise.. Kit: VDC Marquee 8110+, Crystalio 1, Da-lite Cinema Vision fixed screen, HTPC, Denon DVD2900-SDI, Roksan TT, TiVo, EAD processor, Sunfire Cinema Grand Signature amp, Totem Mani-II Ref fronts, rears & centre, Paradigm Servo-15/BFD/REW, Sony ES Dab tuner, Pronto. | |||
