REW YouTube Tutorial - Page 5 - Home Theater Forum and Systems - HomeTheaterShack.com
 1Likes
post #41 of 105 Old 12-27-13, 05:32 PM
Re: REW YouTube Tutorial
Thanks a lot guys for the replies. Literally figured this out just an hour ago after going through countless threads. Much appreciated.
Still it doesn't appear there's a way to calib the card of the MBP. If I do find it I'll post back.
stereo247 is offline
post #42 of 105 Old 12-27-13, 06:31 PM
stereo247 wrote: View Post
I would post it on the "REW forum" to get more exposure.
Any particular reason why you aren't using the laptops soundcard? How old is your laptop?
Phillips is offline
post #43 of 105 Old 12-27-13, 06:36 PM
you do not use the input of the sound card.
Correct
Phillips is offline
post #44 of 105 Old 12-27-13, 06:38 PM
informel
a generic file could be provided by the manufacturer, not the perfect solution, but better than nothing.
or one could use another PC to produce sound at different frequency and adjusting the level at every frequency using an oscilloscope then record the level on the test sound card, but that would be very time consuming.
So practically, you either use a USB microphone and forget about the error from the input of the sound card or you use a regular microphone and go through the whole process
informel is offline
post #45 of 105 Old 08-22-14, 06:10 PM
New Member
Hello, I couldnt get the program running straight. I did everything step by step. this is a brief video of my problem, if anyone can help i would really appreciate it.
RueyBang is offline
post #46 of 105 Old 08-23-14, 05:27 AM
REW Author
JohnM's Avatar
John
RueyBang wrote: View Post
You need to use the beta version of REW to get audio interfaces working properly on the Mac (Apple's version of the Java runtime had a lot of bugs in its audio handling, the beta version has a working Java runtime in it). You can get the beta version here. Note that you need OS X 10.7.3 or later and you should remove REW before you unzip the beta version bundle and drag it into the Applications folder.
JohnM is offline
post #47 of 105 Old 08-23-14, 06:23 PM
New Member
Thumbs up Re: REW YouTube Tutorial
JohnM wrote: View Post
Wow worked wonderfully! Thank You very much
RueyBang is offline
post #48 of 105 Old 08-26-14, 03:04 PM
wes
wes's Avatar
wes
Ok I just downloaded REW new version how do I use my Mac to measure my room!
wes is offline
post #49 of 105 Old 08-26-14, 05:55 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Did you see the link for the YouTube Tutorial in the first post?
post #50 of 105 Old 09-04-14, 03:48 PM
New Member
Thanks for the video! It was very helpful.
Much easier then attempting to figure everything out by trial and error!
Krogstad89 is offline
rew , tutorial , youtube
