REW YouTube Tutorial - Page 8 - Home Theater Forum and Systems - HomeTheaterShack.com
 1Likes
post #71 of 105 Old 02-09-15, 02:43 PM
asere's Avatar
Re: REW YouTube Tutorial
Correct, just load the calibration file for the mic and you're good to go.
Thank you!
asere is offline
post #72 of 105 Old 03-31-15, 07:08 PM
HTS Moderator
Lumen's Avatar
Lou
GIK, thank you for the video! It helped me understand more than I thought I knew.
At the beginning, the narrator mentions that, for instructional purposes, both mains will be measured at the same time. He then goes on to say that (real-world) individual measurements will be made later. I don't think the second video has been made yet, so I looked for help and found it from new member "ntran" in Post #8 of this thread.
The document is a step-by-step guide to REW and holds a wealth of information in a wrritten version as easy to follow as the video!.. Topics like computer setup with HDMI and ASIO4ALL, measuring speaker/sub combinations, and all the workings of REW itself.
Thank you, ntran!
Last edited by Lumen; 03-31-15 at 07:53 PM. Reason: Found answer to question, so posted it here for everyone's benefit
Lumen is offline
post #73 of 105 Old 04-25-15, 08:25 PM
New Member
It was very helpful to learn from this thread that Soundcard calibration is not required for a USB mic. I am using a Dayton Audio UMM-6 mic and did download the calibration file and included it in the REW preferences setup. Currently when I run "Check Levels" I cannot get the input meter to indicate in the recommended range of -24db to -12db FS even with my mic input level set to 100% (in Windows control panel). In indicates about -35db FS and this is based on a 75db signal as measured by my stand alone SPL meter. Is this a problem I should be concerned about?
RazorRay is offline
post #74 of 105 Old 04-26-15, 04:22 AM
REW Author
JohnM's Avatar
John
Nope, nothing to worry about, per the REW help on checking measurement levels: If using a USB mic the signal may be much lower, below -50 dB, this is OK
JohnM is online now
post #75 of 105 Old 07-28-15, 05:00 AM
Zee
Just wanted to thank those involved in the video and the software.
Z...
Zee is offline
post #76 of 105 Old 07-29-15, 01:16 PM
asere's Avatar
I've used REW before with AV connections but now that I tried with hdmi I cannot open the channels on the REW output to select. I am using the Umik 1 mic with the calibrated file. I go to preferences on REW and made sure I selected Asio4, then on input I selected umik1 but for output it says Not Connected. The hdmi is connected to the back of the avr and I can see/display the PC/REW info on the tv screen.
Any thoughts please?
asere is offline
post #77 of 105 Old 07-30-15, 01:36 PM
REW Author
JohnM's Avatar
John
asere wrote: View Post
Could try following the miniDSP article to see if that helps, it covers it all well: http://www.minidsp.com/applications/...dmi-on-windows
JohnM is online now
post #78 of 105 Old 07-30-15, 01:57 PM
asere's Avatar
JohnM wrote: View Post
Thank you. I read it before and I can get every step but somehow I cannot get the output window to display the speaker channels. I know the hdmi has to be set for multi channel output.
How can I verify the hdmi multi channel output?
asere is offline
post #79 of 105 Old 07-30-15, 02:58 PM
REW Author
JohnM's Avatar
John
I don't know, sorry. Were you able to select both the UMIK and the HDMI output on the ASIO4All control panel? Did you restart REW after doing that? What output devices does REW show? Might be worht posting a couple of screenshots of the ASIO4All panel and the REW soundcard preferences. I guess there's also a chance the HDMI behaviour may depend on the surround mode the AVR is set to.
JohnM is online now
post #80 of 105 Old 07-30-15, 03:02 PM
asere's Avatar
I don't know, sorry. Were you able to select both the UMIK and the HDMI output on the ASIO4All control panel? Did you restart REW after doing that? What output devices does REW show? Might be worht posting a couple of screenshots of the ASIO4All pane and the REW osundcard preferences. I guess there's also a chance the HDMI behaviour may depend on the surround mode the AVR is set to.
I was able to select umik for input and for output it says not connected or it says hd something. I needed to check the avr hdmi settings.
asere is offline
rew , tutorial , youtube
