| REW Forum no gain on sub ampDiscuss no gain on sub amp in the Subwoofer Equalization | Calibration forum; no gain on sub amp Hello,
I attempted to install an adcom amp to the LFE channel of an Onkyo receiver. The adcom amp doesn't ... |
| | #1 (Link) | |||
| no gain on sub amp Hello, I attempted to install an adcom amp to the LFE channel of an Onkyo receiver. The adcom amp doesn't have a gain control. .......I think the amp expects a 10V input, I can't get the sub loud enough to blend with the mains.......is there a reccomended line driver used for people with DIY subs?? Thanks Last edited by 420247; 08-18-07 at 04:48 PM. | |||
| | #2 (Link) | ||||
| Re: no gain on sub amp Quote:
Generally the input 'gain' control to an amplifier is simply an attenuator that lowers the input level to the amplifier. brucek | ||||
| | #3 (Link) | |||
| Re: no gain on sub amp unfourtunatly I don't have the model number handy............I thought this may of been a common problem. When attempting to install the sub we tried 3 different amps with the same result (they too had fixed gains) I used REW to send a 60hz sine wave to the Onkyo receiver and measured 100mV AC on the LFE channel with a multimeter. From my reading on this site the output should be around 2V....the amps manuel had an input range of "x"V-10V, I assumed that 10V would be required to drive the amp to full output............the onkyo must have a bad LFE out????? | |||
| | #4 (Link) | ||||
An amp that requires 10volts for maximum out would be a PRO amp. I don't have the specs, so I can't really comment. If your Onkyo outputs 100mvolts at full output, then that is indeed low. Most people here use a line amp if they don't have the level required to supply a Pro level amp. brucek | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Gain and other confusing topics. | wbassett | Projector Screens | DIY Screens | 71 | 01-01-08 08:16 AM |
| Today I noticed amp gain wasn't at 100% and.... | Exocer | DIY Subwoofers | 38 | 07-30-07 11:06 PM |
| Room and Cabin Gain | jackfish | Home Audio Acoustics | 4 | 02-16-07 03:13 PM |
| Porting an IB... looking for room gain... | Chrisbee | DIY Subwoofers - Infinite Baffle | 7 | 01-14-07 05:26 AM |
| Any way to limit gain to +/-10.0 dB? | maxcooper | REW Forum | 17 | 12-16-06 04:08 PM |
