REW Forum
Soundblaster set up problems..
Discuss Soundblaster set up problems.. in the Equalization | Calibration forum; Soundblaster set up problems.. Hi Everyone, Trying to get my Soundblaster live external usb soundcard set up. I installed all the software and started ...
Views: 599 - Replies: 3
Old 08-02-07, 01:14 PM   #1
Alias: cruz
User: #9913
Since: Jul 2007
  cruzmisl is offline
Hi Everyone,
Trying to get my Soundblaster live external usb soundcard set up. I installed all the software and started to calibrate it but the surround mixer only has volume, master volume and cd audio. Everything else is just a grey unnamed slider that I can't use. There is no midi, wave, or the two line in/mic in sliders. Any ideas?
Thanks!!
Joe
Old 08-02-07, 04:09 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Soundblaster set up problems..
I can't come up with anything. Are you saying in the Soundblaster mixer itself (nothing to do with REW), that most things are greyed out?
Can you post a picture of the mixer so we can see it?
What about the Windows Mixer (playback and record). Are you able to select wave and midi etc?
Did you load the software first and then plug in the USB device? Windows is finicky about that....
Old 08-02-07, 06:07 PM   #3
Alias: cruz
User: #9913
Since: Jul 2007
  cruzmisl is offline
I called creative and they said that the SB Live external isn't compatible with Vista Anyone get this thing to work with Vista? I spent all afternoon trying to get it to work.
Thanks!
Joe
Old 08-04-07, 09:17 PM   #4
Alias: cruz
User: #9913
Since: Jul 2007
  cruzmisl is offline
I fixed it. I borrowed a friends laptop with XP on it
