| REW Forum Now what? Please give commentsDiscuss Now what? Please give comments in the Subwoofer Equalization | Calibration forum; Now what? Please give comments To go through these steps only takes a second......
1. Ensure the soundcard and meter calibration files are loaded.
2. ... |
| | #26 (Link) | ||||
| Re: Now what? Please give comments Quote:
| | #28 (Link) | ||||
| Re: Now what? Please give comments Will the BFD allow me to increase the overall sub volume so I can get closer to the 20 hz at the low end and allow me to cut the output from about 25 hz to ~ 90 hz? Based on this quote from the BFD guide it looks like I could: Quote:
| | #29 (Link) | ||||
![]() Hitting 20 Hz is not going to happen with this sub, because response is rolling out too fast below 30 Hz. I mean, it’s dropping well over 30 dB in less than 2/3 of an octave. If that rate were applied to a crossover filter, if could be classified virtually as a “brick wall!” Your plan to reduce output across the board will not work because by the time you EQ everything down to the level 20 Hz is, you will have reduced your overall signal by nearly 30 dB. There probably won't be enough signal left to drive the sub, even with it turned up all the way. Even if there were, there's no free lunch. As far as the SuperCube is concerned, the result will be the same as if you has tried to apply a massive boost to get 20 Hz up - i.e., you'll be working it to death and run the risk of blowing the driver. Def Tech’s 14 Hz extension rating for the SuperCube II I’m confident is fairly optimistic. I don’t think you’re going to find any $800 sub that will realistically get that low, especially one with an 8” driver. With a little boost from the BFD down there you might be able to squeeze 25 Hz out of it, since your sub appears to be fairly capable and you indicated you have plenty of headroom. But that’s about it. Even then, proceed with caution – if you start hearing rude noises from it afterwards, eliminate the below-30 Hz filtering. Regards, Wayne | ||||
| | #30 (Link) | |||
| Re: Now what? Please give comments Well here is the mains plus the sub. It looks pretty good to me, but the level is higher than the 75 dB target. I am wondering if that is because I split the signal from the computer to the left and right channels. Anyway take a look. It seems I got the smoothest response with a 90 degree phase setting and a crossover of 60 hz. Please comment I appreciate it. Still wondering about getting a BFD. | |||
| | #31 (Link) | |||||
I'm wondering if the sub flatness (especially around 25 Hz) is experiencing the effects you described in this post, which is partially quoted here: Quote:
I wonder if your sub isn't compressing at the low end, thereby flattening out with the more signal you give it... That's what it looks like to me -- as you increase power, the signal gets flatter, but not louder. I'd be interested to see more plots, displayed on one set of axes, with increasing preamp levels, while the SPL meter is in an appropriate range. -- Otto | |||||
| | #32 (Link) | |||||
But it certainly is worth a try. Greg, if you're going to take a set of readings at 75dB, 80dB, 85dB, 90dB, 95dB etc, then before each test you would do a complete setup (as I described in detail earlier in the post), except set all the 75dB targets to a new value each test. Also be sure to increase the SPL selector wheel on the RS SPL meter when needed (i.e. for 75dB and 80dB use 80dB position, then move up to 90dB position etc...) Post all the graphs on a single All Measured display for comparison... brucek | |||||
| | #33 (Link) | ||||||
| Re: Now what? Please give comments Thanks again, you guys are fantastic. OK. I took a deep breath and went through your responses again. I went through the setup process after your post but I didn't do this: Quote:
On my previous post where I showed the increases in volume, I did not adjust the SPL meter (using the selector wheel), I just increased the volume. On my last post, I did adjust the volume in the settings window using the speaker level pink noise, but I had not run through the Set Target Level routine and I had the selector wheel on the SPL meter set to 70. I did calibrate the SPL and it was consistent with the 75 dB I was getting on the meter but as you (brucek) has mentioned, I may have run out of headroom on the meter. I'll do more measuring tonight. Quote:
I'll post more after the testing tonight. If I haven't mentioned it yet, man this software is cool! | ||||||
| | #34 (Link) | ||||
I think we'll ask John to change that to a 'button' in the next revision. A lot of people miss that....... brucek | ||||
| | #35 (Link) | |||
| Re: Now what? Please give comments I saw it before.....I just did not know what it did. I guess I thought by setting target level to 75 dB (in the blue lettering) I would be done. Thanks again. On a different subject, I've been reading about house curves - very interesting stuff. | |||
| | #36 (Link) | ||||
| Re: Now what? Please give comments So last night I started from scratch and went through these steps: Quote:
The weird thing is that I had noticed that when I set the target value, via the routine, I had not switched it to full range. So the routine was set using a tone that was supposed to be for the sub only. Then I redid everything for the full range speaker tone and it set the target to 70.2 dB. See second graph. Any thoughts about what is going on? It is pretty much the same response just the target is kind of screwy. | ||||
| | #37 (Link) | ||||
Only use subwoofer setting, even when you add the mains. When you add the mains, simply go through the setup routine again, because the overall level will be different and so REW requires recalibration.. ![]() brucek | ||||
| | #38 (Link) | |||||
| | #39 (Link) | |||||
brucek | |||||
| | #41 (Link) | |||
| Re: Now what? Please give comments So, if that's the case, this is my response for the sub + mains. My crossover is at 80 hz and the sub is at about 15% of max output (turned down very low). If I get a BFD I should be able to bring down the peaks at 40 hz and 90 hz, right? Any other suggestions? Thanks again, brucek, for your help in getting my mind right. I have the ability to control the crossover for the center channel seperately, so I will post that graph later. | |||
| | #42 (Link) | ||||
The 90Hz is more a function of your mains than the sub (which you're able to EQ). See the level of the target curve at 90Hz? That's the level (and the lesser influence) that the sub is offering to the mix at 90Hz. The mains contibute the most to 90Hz. Often though, you can adjust the phase control of the sub (and somethimes the distance control of the receiver) and get the crossover area to flatten out. Simply take repeated mesaurements while adjusting the phase and then the distance control of the sub and watch the 90Hz area and see if it doesn't respond. Yes, you can also try and put a small negative filter at 90Hz and you may pull the hump down also... Overall your response is quite good though. brucek | ||||
| | #43 (Link) | ||||
| | #44 (Link) | ||||
brucek | ||||
| | #46 (Link) | ||||
| Re: Now what? Please give comments That last curve is the best I can do. I tried some different phases and crossovers, but that seems to be the flattest I can get. One more question. Has anybody just used the sub to get a house curve? I don't have a BFD (for now anyway) but I was wondering if I could use this method described by Wayne: Quote:
| | #47 (Link) | |||
| | Re: Now what? Please give comments If 70 Hz is your crossover frequency, then yes 70 and 30 Hz is a good place to start. Typically people generate their house curve with the sub, since it’s the only thing receiving precise equalization. At that point, if the mid-to-upper bass sounds thin (or bloated) that would be from the mains, and addressed by placement and/or receiver tone controls. Regards, Wayne | |||
| | #48 (Link) | |||||
| Re: Now what? Please give comments Hi Wayne. Thanks again for your input. Quote:
I thought that since my response is flat (and on target) at 70 hz, that was where I should shoot for. Would it be better to shoot for 80hz since it is the crossover?? Quote:
Thanks. |
