| REW Forum Now what? Please give commentsDiscuss Now what? Please give comments in the Subwoofer Equalization | Calibration forum; Now what? Please give comments I've always thought that my ears are not very accurate in terms of sound level between two frequencies. Is there ... |
| | #51 (Link) | |||||
| | Re: Now what? Please give comments Quote:
So you might eBay one, like I did. Typically they sell for $50-65. Hard to go wrong at that price, and you can always flip it if you aren’t duly impressed.Regards, Wayne | |||||
| | #52 (Link) | ||||||
| | #55 (Link) | |||
| Re: Now what? Please give comments ok. Here are my results (trying for a house curve without an EQ). The first graph is the sub turned up so 30 hz and 70 hz matched (I think) by ear. The second graph is the sub as flat as I could get it and the third graph is a compromise between the two. I took a few other measurements between but I liked the way the third graph looked so I stuck with it. Does it look better than the flat response? I will do some listening and let you know. Last edited by angryht; 08-14-07 at 07:20 AM. | |||
| | #56 (Link) | |||
| Re: Now what? Please give comments Well, I've watched (listened to) a few movies with the low end boosted (my last graph in the previous post). I am not sure I could tell the difference, most likely because the movies I've watched have been heavy on the dialog. I guess in my mind I am still struggling with the 'house curve concept'. I always thought the goal was to get as flat a response as possible. However, the idea that my ears don't 'listen' that way is quite interesting. Are there any other resources to go through to get a better handle on this? | |||
| | #57 (Link) | |||
| Re: Now what? Please give comments I went back and read the house curve sticky at the beginning of the this area. The x-curve explained here: http://www.hometheatershack.com/forums/1307-post3.html is -5 dB at 20 hz and 0 at 63 hz. Wouldn't the goal be to invert that with my response in my home theater? Shouldn't I just dial in a house curve of 0 dB at 63 hz and +5 dB at 20 hz, draw a straight line from point to point via the house curve funtion in REW and try to match that? Are movie theaters speakers responses set up to invert the x-curve so it 'sounds like' a flat response? | |||
| | #58 (Link) | |||
| Re: Now what? Please give comments Here is the sub turned down a little bit more to try to match the house curve of 0dB at 63hz and +5dB at 20 hz. I would think this would be better to match the x-curve????? I suppose the big problem is still the big hump at 40 hz. | |||
| | #59 (Link) | ||||||
This is all academic, until you get an equalizer. I lieu of that, I suggest setting your curve (which in your case means adjusting the sub up or down) with music as a starting point. That’s a good reference point, because it’s easy to tell when it sounds right because the bass blends with the rest of the signal. Get a good blend there, then try some action movies, not “dialog” fare. You may find you need to then turn it up the sub a little, but that should be about it. Regards, Wayne | ||||||
| | #60 (Link) | |||
| Re: Now what? Please give comments Thanks again, Wayne, for helping me wrap my mind around this stuff. I'm not sure I understand. If that's the case wouldn't you want to try to match the response of the movie theater which would be just the opposite of putting in a house curve. | |||
| | #61 (Link) | |||
| | Re: Now what? Please give comments For one, a movie theater, even a small one, is many times larger than your room. Remember, different sized rooms require different curves. That said, not sure how you arrived at the conclusion that the x-curve is the opposite of a house curve. Regards, Wayne | |||
| | #62 (Link) | |||
| Re: Now what? Please give comments I mean at the low end. The typical house curve is higher below the crossover point (~80 hz) and the x-curve cited in the house curve thread (shown below) drops below 63 hz. | |||
| | #63 (Link) | |||
| | Re: Now what? Please give comments The movie industry has their own version of what a house curve should be, that suits their purposes. For instance, they may be reducing below 63 Hz to minimize low frequency bleed-through to adjoining theaters. Again, the X-curve discussion was only meant to show that house curves are necessary both in production and playback. The X-curve itself is of no use in a home theater, unless one happens to prefer sagging lows and highs. Regards, Wayne | |||
| | #64 (Link) | ||||
Still a little confused but I think I am getting it. | ||||
| | #65 (Link) | ||||
![]() Regards, Wayne | ||||
| | #66 (Link) | |||
| Re: Now what? Please give comments Thanks again, Wayne. So, does that mean if a person listened to a speaker (and the speaker measured flat) in an anechoic chamber, it would sound good? And the only reason for the house curve is to compensate for the room acoustics? | |||
| | #67 (Link) | |||||
![]() Quote:
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Conceptuals, would love comments | formspace | Home Theater Design and Construction | 14 | 07-15-07 07:13 PM |
| House Curve Comments | BigPines | REW Forum | 8 | 07-13-07 08:11 AM |
| What would an upgrade give me? | PhilB35 | SVSound | 19 | 02-17-07 10:41 PM |
| SoundSplinter Giveaway Questions and Comments Thread | Sonnie | SoundSplinter | 21 | 10-19-06 06:04 PM |
| 1st attempt with BFD... your comments? | highcurrent | REW Forum | 8 | 05-07-06 03:03 PM |
