What exactly can I read from the group delay graphs?
As an example let me first refer to the spl graph. I think a flat spl response is good. A dip in it can have various causes for example I may getting cancellation because two out of phase signals are interfering with each other, or I may be measuring at a mode null. I can with this knowledge take some action.
In the case of the excess group delay I also have a graph which I think should be flat and also be at zero. Fine, it isn't. The REW help documentation seems to imply that the non-zero not flat bits are caused by reflections. Can the non-zero excess group delay be caused by anything else?
The graphs shows an excess delay of 28.4ms at 324 Hz. To start with what does the time mean? My first thought was to work out the distance this is equivalent to (9.75m) and if that idea is not incorrect then there must be more than one wall involved in the reflection. Another idea I was not too successful with was looking at the ETC and applying a filter: I tried the 315Hz one as it is the nearest to 324Hz with the idea that might show me when the 324Hz reflection arrives.
Possibly what I am doing is rubbish, perhaps not, either way someone please clarify what the excess group delay and min group delay (now, that is hilly country) graphs can tell us.
Markus
Markus
