| REW Forum newby questionsDiscuss newby questions in the Equalization | Calibration forum; newby questions I'm brand new to this REW/BFD stuff. I thought I was going to be able to use by "m-audio revolution ... |
Views: 466 - Replies: 1
| newby questions I'm brand new to this REW/BFD stuff. I thought I was going to be able to use by "m-audio revolution 5.1" sound card with REW/BFD. It appears it is not capable of duplex operation so I realize now I will need another sound card to use with REW. The threads I've found on this forum concerning best sound cards are a little old. Are the "soundblaster 24bit usb" and "soundblaster mp3+ usb" still considered the (best/easiest/cheapest???) cards to use? My main source component for my stereo/HT is my computer so my plan would be to still use my m-audio card as my digital source and to hook up the external usb card temporarily to measure with REW and set up BWD. (I assume I might have drivers that will need to be uninstalled and reinstalled to actually do this) Am I right in thinking that once the BFD is set up and running that the external soundcard used to do this is not needed unless new measurements/setup is needed? I have a Behringer ECM8000 and phantom power supply. It looks like I also need a SPL meter. Is this true? On reviewing the manual for REW setup I see items talking about not using mic input on the sound cards. Is this only done when calibrating? When actually using the mic would the mic input be used? I see that a midi interface is not necessary. Is the midi interface only used to upload filters to the BWD? How hard is it to enter filters manually into the BWD? To summarize, here are my questions. (I'm sure a lot more will be coming) 1. Will my "m-audio revolution 5.1" sound card work with REW? 2. What would be the easiest/best/cheapest soundcard to use? 3. In my case would the external soundcard only be needed when setting up REW/BFD? 4. On top of having a microphone do I also need a SPL meter? 5. When using a microphone, is the mic input on the soundcard used? 6. Is the midi interface only used to upload filters to BWD? 7. How hard is it to enter filters manually into the BWD? Thanks in advance for any help/advice that can be given. | ||||
| | #2 | |||||||||||
| Re: newby questions Quote:
![]() brucek | |||||||||||
