Sticky Thread: Room Mode Calculator and Converter. - Problem - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
REW Forum
Discuss Sticky Thread: Room Mode Calculator and Converter. - Problem in the Subwoofer Equalization | Calibration forum; Sticky Thread: Room Mode Calculator and Converter. - Problem I have tried to use the Room Mode Calculator on the above tread, but no matter what figures are put ...
Old 06-06-06, 12:47 PM   #1 (Link)
Alias: Mike Oates
Loc: Manchester, UK
MikeOates's Avatar
User: #873
Since: Jun 2006
MikeOates is offline
I have tried to use the Room Mode Calculator on the above tread, but no matter what figures are put in the room size, even leaving those in that are in the file, caused an error...
Run-time error '1004':
Application-defined or object-defined error
I presume the room sizes are in feet?
Mike
Old 06-07-06, 01:21 AM   #2 (Link)
Loc: Lower Alabama
Sonnie is offline
Re: Sticky Thread: Room Mode Calculator and Converter. - Problem
Hey Mike... did you enable macros?
I just downloaded it and it worked fine for me as long as I enabled macros. If I diable macros I get errors too.
Yes... the sizes are feet.
Sonnie
Old 06-07-06, 01:45 AM   #3 (Link)
Alias: Mike Oates
Loc: Manchester, UK
MikeOates's Avatar
User: #873
Since: Jun 2006
Sonnie,
Yes, macros are enabled. Could the version of Excel be a problem, I have Excel 2000 (9.0.3821 SR-1)
Mike
Old 06-07-06, 02:25 AM   #4 (Link)
Loc: Lower Alabama
Sonnie is offline
Yup... it's a 2003 version. I suppose I can save it in an older version, but I'm not sure which is which. Is 2000 version 2.1, 3.0 or 4.0. Looks like those are the only Workbook choices I have.
Sonnie
Old 06-07-06, 02:43 AM   #5 (Link)
Alias: Mike Oates
Loc: Manchester, UK
MikeOates's Avatar
User: #873
Since: Jun 2006
Sonnie,
Could you try version 4 as I have Excel 2000 (9.0.3821 SR-1) The numbering implies I have version 9. (I assume)
Mike
Old 06-07-06, 02:51 AM   #6 (Link)
Loc: Lower Alabama
Sonnie is offline
It wasn't acting right when I saved ... claims version 4 doesn't have all he features, but I saved it anyway and you can try it.
hardman might be able to fix it up in 2000.
roomcalculator_v4.xls
Sonnie
Old 06-07-06, 03:24 AM   #7 (Link)
Alias: Mike Oates
Loc: Manchester, UK
MikeOates's Avatar
User: #873
Since: Jun 2006
Sonnie,
It can't find two macro's 'roomcalculator_v4.xls!Clear' and 'roomcalculator_v4.xls!Merge' These message appear when I press the buttons 'Clear' and and 'Plot'. Also when opening the file it does not ask me if I want to enable macros, so they don't seem to be included in the file.
Don't worry about it, I don't want you spend too much time on it, I don't fully understand what it would tell me anyway, still a lot to learn.
Mike
Old 06-07-06, 10:43 AM   #8 (Link)
Loc: Lower Alabama
Sonnie is offline
I suppose those features that are missing are ones that could not be saved in version 4.0. I'll see if hardman can fix up a 2000 and 2002 version for us. I'm pretty much clueless with creating a workbook like he did.
Sonnie
Old 06-08-06, 01:52 AM   #9 (Link)
Loc: Lower Alabama
Sonnie is offline
Hey Mike... hardman saved it as an older version. Try it now from the sticky thread.
Sonnie
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
