Anyone get REW/soundblaster to work with Vista? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Anyone get REW/soundblaster to work with Vista? in the Subwoofer Equalization | Calibration forum; Anyone get REW/soundblaster to work with Vista? I'm having a heck of a time getting it to work. I was finally able to load the driver only ...
Old 08-02-07, 07:56 PM   #1 (Link)
Alias: cruz
User: #9913
Since: Jul 2007
cruzmisl is offline
I'm having a heck of a time getting it to work. I was finally able to load the driver only but can't get the REW settings to work. Some are there and some are greyed out.....
Thanks,
Joe
Old 08-03-07, 02:53 AM   #2 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is online now
Re: Anyone get REW/soundblaster to work with Vista?
If REW can't access the various volume settings via the device's driver it will not enable the corresponding controls, you then have to use the controls in the Windows mixer or the soundcard's own mixer (but sounds like you can't load that under Vista).
Old 08-03-07, 08:18 AM   #3 (Link)
Alias: cruz
User: #9913
Since: Jul 2007
cruzmisl is offline
I don't think it works either. I'm trying to get a dual boot going but that only toasted my Vista boot loader and I had to reload my OS
If anyone got it working with VIsta some tips would be appreciated. I have all this new equipment I can't use
Old 08-27-07, 05:36 PM   #4 (Link)
New Member
Alias: Brad
User: #9525
Since: Jun 2007
Brad is offline
After 6 months of trying various driver hacks that didn't work (or did, but not for long) I came up with a simple solution - I installed Linux.
Old 08-28-07, 09:23 PM   #5 (Link)
Alias: Edward
Loc: Brampton ON, Canada
User: #8188
Since: Apr 2007
clubfoot is offline
cruzmisl wrote: View Post
Vista does not support DirectX sound, so unless you can load specific Vista drivers for your Soundblaster card you are out of luck. Basically you can either purchase an XFi Soundblaster or upgrade back to Xp Pro and regain compatibility.
Old 08-28-07, 10:20 PM   #6 (Link)
Alias: cruz
User: #9913
Since: Jul 2007
cruzmisl is offline
Is this what I need?
http://www.newegg.com/Product/Produc...829102009#spec
Old 08-29-07, 03:31 PM   #7 (Link)
Alias: Brent
Loc: Wilmington, NC
brent_s's Avatar
User: #7037
brent_s is offline
Cruz, can you describe what's not working? Witht the latest drivers posted by Creative, I'm able to use REQW with a SB Live External. You won't have all of the controls available with XP. My biggest issue was I couldn't get the input/output level difference within the recommend range when doing the soundcard calibration, but the REQW docs said do the best you can in that case. Despite the lower than desired input level, my soundcard calibration and sub measurements look pretty much the same as they did when the same card/mic was used on an XP machine.
-Brent
Old 08-29-07, 04:26 PM   #8 (Link)
Alias: cruz
User: #9913
Since: Jul 2007
cruzmisl is offline
It's been a while so I'm not too sure. I used a friends old laptop with XP on it and it works fine but it's really slow. If I could buy the one in the link and not have any issues then I would, just to save some time and give my buddy his stuff back
Similar Threads
Will my Sound Blaster Audigy 2 ZS work in REW? bobmills REW Forum 8 06-01-07 05:19 PM
Will ADS Technologies Pyro A/V Link work with REW? camtah REW Forum 0 02-13-07 08:24 AM
SoundBlaster Live Problem Ciscokid REW Forum 7 01-07-07 02:53 PM
How to make all this work (SPL to REW to BFD) help rlammi REW Forum 87 08-10-06 09:10 PM
Soundblaster 24bit problems. TonyB REW Forum 4 07-04-06 02:25 PM
Mach 5 Audio
