| REW Forum sound card calibration problemsDiscuss sound card calibration problems in the Equalization | Calibration forum; sound card calibration problems Hello everybody
making soundcard calibration measurements,looped speaker o/p to line i/p,followed procedure(I think), but on the sound meter readings the ... |
Views: 538 - Replies: 13
| sound card calibration problems Hello everybody making soundcard calibration measurements,looped speaker o/p to line i/p,followed procedure(I think), but on the sound meter readings the o/p is giving a top reading of- 9.0 and a bottom reading of -12 but the line in top reading is -66 and bottom of -110 (fluctuating) ie. virtually no signal.What am I doing wrong.(The readings are the numbers at the top and bottom of vu meters) Regards:Alan | ||||
| | #4 | |||||
| Re: sound card calibration problems Quote:
If you have only two silver segments, then you have a mono plug, and that is likely your problem. -- Otto | |||||
| | #5 | |||||
I guess you mean something like this? ![]() brucek edit: oops, cross post with otto............... | |||||
| | #6 | ||||
| Re: sound card calibration problems hello brucek/otto I`m using the cable eqivalent as in your getting started guide and joining them them with the phono to phono adapter, and the 1/8" has the the two black rings. regards:Alan | ||||
| | #7 | ||||
| Re: sound card calibration problems OK, that seems fine then. Can you post a picture of the REW settings screen (and tell us the name and model of the soundcard)? Here's a pic of mine to show you what I'm looking for. ![]() ![]() brucek | ||||
| | #8 | ||||
| Re: sound card calibration problems Hello brucek, will send picture when I work out how, however the view is just about like your settings but my card is fortissimo III 7.1.My input volume is 1.0 where I have been trying to adjust it, the only other difference is that you have the calibration file and mine at this point says none.other than that it is the same. | ||||
| | #9 | ||||
| Re: sound card calibration problems OK, are you sure (no offence) that you have the line-in correctly identified on the soundcard itself and it's connected to front out. It's so easy to plug into the wrong jack with so many available. Do you have all the EQ and effects turned off in the Hercules software application. You also must be in stereo 2.0 mode with no small selected. brucek | ||||
| | #10 | ||||
| Re: sound card calibration problems Hello brucek Checked connections, all ok, must be, as you say some effect not disabled,will keep trying,thanks for all your help.Could you recommend a simple ,cheap soundcard if I can`t sought this out. Reagards; Alan | ||||
| | #11 | ||||
| Re: sound card calibration problems This thread is quite revealing. I think you should read it. ![]() The member shows tab for tab how he solved the problems he was having with the same card as you have. Give it try before thinking about replacing your card... ![]() brucek | ||||
| | #13 | |||||
Bruce, I have the Realtek soundcard as well. I am using a Toshiba laptop and I identified the output I believe (marked with a headphone symbol) however the only input I see is apprears to be a Mic input. Perhaps I missed something? Any help is appreciated. Regards, | |||||
| | #14 | |||||
brucek | |||||
