| REW Forum This what i got so farDiscuss This what i got so far in the Subwoofer Equalization | Calibration forum; This what i got so far This is the first mesurments i have done. I have not used the BFD yet. I just want to get ... |
| | #2 (Link) | |||
| Re: This what i got so far It's a pretty good response. A BFD would indeed fix that fairly easily. You should try and do the response with the subwoofer only, so as to eliminate the mains interaction. brucek | |||
| | #6 (Link) | |||
| | Re: This what i got so far It's kinda hard to say. Six months ago we would have all probably said you are fine if it sounds okay to you. But since then we've learned a little more, having the benefit of Room EQ Wizard at our fingertips. There might possibly be some more serious problems that what 1/6 octave measurements will show us. Using REW and a sweep from 10hz to 400hz will give us a better (more accurate) picture of your response. If you don't want go through having to connect up your computer in your HT area, you can always take 1hz increment measurements from 10hz - 160hz or so and save them in a .txt (text) file, then load them into the REW software. BUT, having said all that, IF it sounds good like it is to you and you are not concerned that you might be missing anything between those frequencies, stay as you are. | |||
| | #7 (Link) | |||
| Re: This what i got so far Admittedly, the sub only plot looks quite good, but your sub + mains graph has revealed an interaction that may require some BFD filtering. The BFD obviously has a lesser effect on the combined (sub + mains) response as the frequency increases, but can still provide useful equalization at and somewhat above your crossover. This may be useful to you in the 60Hz to 100Hz area shown in your combined graph. Generally, we suggest a sub only response, that is then filtered with the BFD to create the desired target. Then add in the mains to check for interaction and adjust phasing to get the best results. Then, if there is an interaction problem that phasing can't remove, do some minor tweaking with the filters to try and solve the problem. I completely agree with Sonnie that problems are exposed with the sweep provided in REW that 1/6th octave single tone measurements don't let you see.... brucek | |||
| | #12 (Link) | |||
| Re: This what i got so far Hey sonnie I'm back. I just had to take care of some family problems. It left me with no time to play with my sub or BFD. I'm going to try to adjust some more this weekend. I post some new results. ![]() | |||
