| REW Forum soundcard calibration, what am I doing wrong.Discuss soundcard calibration, what am I doing wrong. in the Subwoofer Equalization | Calibration forum; soundcard calibration, what am I doing wrong. I am using a M-Audio Revolution 5.1 soundcard with Windows Vista as my OS. When trying to calibrate the soundcard ... |
| | #1 (Link) | |||
| soundcard calibration, what am I doing wrong. I am using a M-Audio Revolution 5.1 soundcard with Windows Vista as my OS. When trying to calibrate the soundcard I can get to the point of having all my settings apparently correct but when I hit the next button to go to actual measurement the "Start Measuring" button is grayed out and nothing happens. Please refer to the attachments of my settings screen and measure screen. Thanks for any help that can be given. | |||
| | #2 (Link) | ||||
| Re: soundcard calibration, what am I doing wrong. Quote:
If that isn't happening some sort of error might have occurred, if so there will be a log of what happened in the debug files. To locate those, open the Help / About box to see where your home directory is (i.e. C:\Documents and Settings\yourname). The log files are stored there. Look for files called roomeq_wizard0.txt, roomeq_wizard1.txt etc. Open each file in any text editor (e.g. Notepad) and see if there are any error messages. A new file is created each time REW is started, the last 9 copies are kept in a rotating list. What does the error (if any) say about what's happening? brucek | ||||
| | #4 (Link) | ||||
So, it's just hanging for some reason. Have you tried the Settings Pulldown and selected 'Delete Settings and Restart'. Does REW hang when you go to the Measure routine and select Measure or does it execute the sweep (don't worry that its not setup, I just want to see if it will measure). brucek | ||||
| | #5 (Link) | |||
| Re: soundcard calibration, what am I doing wrong. I am running Vista too and mine would hang as well but not at the same spot. Usually when I hit calibrate it would hang. I just restarted the system, tried again and it worked. It does it every once in a while...... | |||
| | #6 (Link) | |||
| Re: soundcard calibration, what am I doing wrong. tried restarting computer with no effect. tried 'Delete Settings and Restart' with no effect. When go to measure the "measure" button is active but after clicking nothing happens. | |||
| | #10 (Link) | |||
| Re: soundcard calibration, what am I doing wrong. That would typically happen if you don't have the input signal reaching REW, if that is the problem you will need to select the Line In input on your card via the card's mixer and set the volume level etc as you do when letting REW control volumes, but using the card's mixer controls. If that's not the problem post screenshots of the impulse response and scope graphs after trying a measurement. | |||
| | #11 (Link) | |||
| Re: soundcard calibration, what am I doing wrong. still using default as input and output. Used soundcard driver software to set volume. results are posted. 1 filter adjust 2 impulse 3 all measured 4 all predicted 5 all impulses 6 scope | |||
| | #12 (Link) | |||
| Re: soundcard calibration, what am I doing wrong. From those plots the signal from your line input is not getting to REW, all that is getting through is noise. If you post screenshots of your soundcard's mixer settings we might be able to spot what is wrong. | |||
| | #13 (Link) | |||
| Re: soundcard calibration, what am I doing wrong. I know this won't help but it is likely your soundcard isn't compatible with Vista. I couldn't get my SB Live to work with Vista so I bought an X-fi usb soundcard and it works fine. I just got tired of playing around with it. Works fine now. May want to spend the $80 rather than spend hours upon hours trying to figure it out..... Then again there are much smarter people on this board than me so hopefully they'll be able to figure it out. | |||
| | #18 (Link) | |||
| Re: soundcard calibration, what am I doing wrong. Well that didn't work. I've got to thank everyone for the help. I think I'm going to give up on doing this with the m-audio card. Are people having good results in Vista and with what sound cards. | |||
| | #19 (Link) | ||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| E-MU 1616M soundcard calibration help needed. | Frank_S | REW Forum | 24 | 12-04-07 04:41 PM |
| What did I do wrong? | Kingrsl | REW Forum | 1 | 03-07-07 09:42 PM |
| SB Live External soundcard calibration not working | daxie | REW Forum | 3 | 01-24-07 01:38 AM |
