Need a soundcard for REW? How about X-Fi for $20?? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Need a soundcard for REW? How about X-Fi for $20?? in the Subwoofer Equalization | Calibration forum; Need a soundcard for REW? How about X-Fi for $20?? Works great with my Laptop running Vista. Act fast. The $30 rebate is only good until September 25th. Enjoy and ...
Old 09-21-07, 09:58 PM   #1 (Link)
Alias: cruz
User: #9913
Since: Jul 2007
cruzmisl is offline
Enjoy and share the wealth
http://shop4.outpost.com/product/5019995
Old 09-26-07, 06:04 PM   #2 (Link)
New Member
Alias: rich
Loc: chicago, il
User: #7337
Since: Mar 2007
richh is offline
Re: Need a soundcard for REW? How about X-Fi for $20??
Thanks for the heads up... I ordered one and it arrive this afternoon.
A bit of a problem though. I haven't tried it with a mic and REW just yet. I thought I would start out with just a simple task of playing mp3's. I connected it to my Vista based laptop through the USB, and then plugged the included headphones into the headphone jack on the XMOD. The drivers and whatnot loaded sucessfully, but when I go to play an mp3 through Windows media player, i do not get any audio thhrough the headphones. Instead I get a error something to the effect of Windows media player cannot play the file because there is a problem with your sound device. Does yours work with Media Player?
edit: Well it must be a vista thing. I tried the XMOD on an older desktop running Windows XP and it seemed to work ok. I guess I need to figure out why Vista doesn't like it.
Old 09-26-07, 11:54 PM   #3 (Link)
Alias: cruz
User: #9913
Since: Jul 2007
cruzmisl is offline
never tried it with headphones. I'll give it a try and report back.
Similar Threads
Could I use this soundcard with REW? cruzmisl REW Forum 2 09-05-07 08:51 PM
REW Issue #1: Calibrating SoundCard JCD REW Forum 7 05-01-07 05:08 PM
Soundcard: PC vs USB for laptop? 16 vs 24 bit for REW and more? tweakophyte REW Forum 4 03-25-07 04:05 PM
REW will not calibrate the soundcard Ivaols REW Forum 7 01-26-07 01:19 PM
New Soundcard drivers gives REW an error. Exocer REW Forum 8 06-18-06 02:20 PM
Mach 5 Audio
