| REW Forum Some tips for good measuringDiscuss Some tips for good measuring in the Subwoofer Equalization | Calibration forum; Some tips for good measuring The last couple of days I have been real busy with REW.
I discovered some simple things that can improve ... |
| | #1 (Link) | |||
| Some tips for good measuring The last couple of days I have been real busy with REW. I discovered some simple things that can improve the results of your measurements. - Disable as much services as possible. I use this website for good guides for tweaking my system: http://www.blackviper.com/WinXP/servicecfg.htm http://www.blackviper.com/WinXP/supertweaks.htm Your system doesn't have to swap between a lot of processes and resources anymore. - Disable as much devices as possible in your hardware device manager. If you have a wireless network card, disable it before you start measuring. Same goes for other audio devices. - If you use a laptop, use a full battery and disconnect your power cable before you start the measuring. Last edited by krunk; 09-27-07 at 02:38 AM. | |||
| | #2 (Link) | |||
| Re: Some tips for good measuring OK, I have to ask, why? Unless you have an under powered system where the system services are interfering with REW measurements I don't see the need to turn off devices. Did you observe some odd behavior with these services/devices enabled? | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| measuring bass trap effectiveness | Nate | Home Audio Acoustics | 16 | 09-09-07 09:57 AM |
| Measuring driver excursion | Chrisbee | DIY Subwoofers | 24 | 06-03-07 02:10 AM |
| New CEA 2010 method for measuring true subwoofer performance | Tom Vodhanel | SVSound | 8 | 02-17-07 07:34 AM |
| Wierd results when measuring soundcard response, need new S/Card?? | terry j | REW Forum | 41 | 10-26-06 09:53 PM |
| REW - Possible?? Measuring using Pink Noise from Source Player | media2368 | REW Forum | 8 | 05-16-06 01:12 AM |
