Sound Card Calibration Help - Newb - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Sound Card Calibration Help - Newb in the Subwoofer Equalization | Calibration forum; Sound Card Calibration Help - Newb Hi, Just downloaded REW and am having a heck of a time calibrating the SB Live USB card. I have ...
Old 09-30-07, 07:46 PM   #1 (Link)
pbc
Alias: pbc
User: #11272
Since: Sep 2007
pbc is offline
Hi,
Just downloaded REW and am having a heck of a time calibrating the SB Live USB card. I have adjusted all the settings and connections as per the FAQ threads on REW and the SB Live. When I calibrate the mic, I get the following graphs. Just wondering if this is what I'm supposed to see as I just can't figure it out!!
Thanks!
Steve
Old 10-01-07, 07:00 AM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Sound Card Calibration Help - Newb
Looks good to me. You should of course save that soundcard calibration file.
The reason it looks strange is a result of the exaggerated scaling used when the soundcard is calibrated. The vertical axis is only -3dB to +3DB. See the green line in the response. That is the soundcard calibration. It's only down about -2.5dB at 5Hz. That's a great response. REW will apply a curve exactly opposite to that green line after you take measurements to compensate.
The black line shows the microphone response curve. When exaggerated it does look bad, but modify the vertical axis and you'll see it's all fine.
Carry on, take measurements....
Old 10-01-07, 08:47 AM   #3 (Link)
pbc
Alias: pbc
User: #11272
Since: Sep 2007
pbc is offline
Okay thanks, the black line is what had me worried!!
Cheers,
Steve
Similar Threads
sound card calibration problems baritone REW Forum 13 09-28-07 01:35 PM
Sound Card Calibration aceinc REW Forum 99 04-22-07 02:30 PM
Sound Card Calibration Problem allredp REW Forum 30 04-01-07 06:58 PM
Sound Card Calibration Problems rean1mator REW Forum 5 02-06-07 02:51 PM
Looking for a sound card Otto Computers | Games | HTPC | Digital Devices 1 02-05-07 02:30 PM
Mach 5 Audio
