A new solution: OSXJack. Works great!
I've conquered the loopback and OSX limitation issues and solved some Mavericks issues. I think this solution is actually fun. It's certainly more elegant in my mind than the previous workarounds. It doesn't even feel like a workaround. Now that I've caught your attention, here are
Instructions for using REW with loopback with OSX Mavericks, using JackOSX.
This method makes the ergonomics easier. Adapt this to your needs as you wish. JackOSX is very versatile. You can feed multiple outputs at once if desired. Jack replaces and surpasses the power of both Soundflower and Line In. The interface I'm using is the Motu Audio Express. Any interface which has combo mike/line inputs and which has two analog inputs as its first pair will work easily. Make a 1/4" to 1/4" analog patch cord for the analog loopback.
My goal: To feed REW's test signal to the digital input of a DAC, and selectively feed either the left or right channel so we can test either the left or right loudspeaker. AND, to have analog loopback from the interface so we can measure time-of-flight latency and center the microphone between left and right loudspeakers. If you are using an analog feed to your loudspeakers it's just a little less patching, but still you will need JackOSX.
UPDATE: I made this test with the MOTU interface's USB connection. When I tried Firewire I could not get it to work on my Retina/Mavericks or my MacPro/Snow Leopard. It would not appear as a device in OSX Sound Preferences. Perhaps the Motu driver is too new and will only work with Mavericks on a Mac which has native firewire, but I do not have Mavericks installed on the MacPro. If you have a Firewire interface and a Mac with native firewire (as opposed to a Thunderbolt adapter) perhaps this procedure will work.
1) Install JackOSX.
http://sourceforge.net/projects/jackosx/?source=dlp. It's also free. Thank heaven for the developers! I found JackOSX 0.89 is completely stable in Mavericks. It's even more stable than Audio MIDI setup, which crashed for me all the time when I was trying the other workarounds. You won't even have to touch Audio MIDI setup for this procedure! JackOSX has thorough and easy-to-understand documentation. Jack allows you to patch any audio application (in fact multiple applications at once if desired). Read the JackOSX documentation. If some parts are a little obscure, they will become clear as soon as you use it. You will have to restart your computer after the install as JackOSX becomes part of the underlying operating system and becomes a device for sound input and output.
2) Run JackPilot, which has been installed in applications. Put the application in your dock for regular use. In Jack Preferences, set Press Start in JackPilot. This will enable JackRouter as an available output and input device.
3) In JackPilot Preferences, set JackPilot as pictured in the attached image. If your interface has fewer input or output channels, you can set it for less. Leave the Auto-connect off, it adds unnecessary patches for our purposes that you will have to unpatch. Leave System port monitoring off, it doesn't harm to turn it on, but it adds unnecessary inputs/outputs to Jack's patching matrix.
4) In OSX Sound preferences, set JackRouter as the Default output device, as pictured in the attached image. There is no need to set anything as your default input device, but you could set the Motu as the device so you can see the Motu mike signal on OSX's meter as a test. This is because REW has to use the default device as its output, but REW can choose your interface directly as its input device. REW defaults to the first two inputs of the interface for its main and reference inputs. (This procedure could be done with JackRouter as the default input device but it is unnecessary and would add extra patching within Jack.)
5) Connect your microphone to Motu input 2. For some reason the main input of REW defaults to input 2 and the Reference input to input 1. Who knows... UPDATE: This was true on my Macbook Pro/Mavericks. On the MacPro/Snow Leopard, Mike 1 is the input and Line input 2 is the reference. I have no idea at this point how consistent this will be, so check it. See where the mike comes up and if it comes up on the wrong input of REW, reverse things. Remember to switch off phantom power before unplugging a condensor mike!!! Connect an analog 1/4" patch cord from Motu Main out 1 to Line in 1 (or line in 2 if appropriate) for the loopback.
6) Launch REW. Go to Preferences/Analysis. Turn on Use Loopback as timing reference. Go to Soundcard. Set the output to the default device. Set the input to the Motu interface. Choose Use Main Speaker to Check/Set Levels. Press Check Levels. Press Next.
7) Switch to JackPilot. Press
Routing. This opens the Connections manager. In a moment, JavaApplications will appear at the bottom of the connections manager. Now we will route REW's outputs to the Motu's SPDIF output(s) AND simultaneously to the Motu's main analog outputs. As pictured in the attached image.
Triangle open the system and the JavaApplications send and receive ports to reveal all the available patch points. Since REW is directly accessing the MOTU on its input, JavaApplications Receive ports will NOT appear in JackRouter. You only have to configure the SEND from REW in Jackrouter. REW itself takes care of the input and return audio. Click on JavaApplications out1 in the left hand column. Click on system playback_1 in the right hand column. Double click on playback_1. It becomes red which means that out1 is routed to playback_1. You should see output on Main 1 on the Motu. AND, presto ---- you will see the mike signal on REW In and the reference signal on REW Ref In!
NB: If you make a mistake in patching in JackOSX, just double click on any node and it will unpatch. Quite elegant for a non-gui application!
Test your work: Pull patch cords to see what happens. Turn the phantom power on the mike on and off and observe that things are patched correctly. This proves the loopback and the Input are working properly. If you are using analog out to loudspeakers, route out1 to playback_2 and this will allow you to feed your analog speakers with an analog cable without a Y cord. But you will have to move cables around to select speakers. With my method you can be a couch potato.
NB: REW feeds both output 1 and output 2 simultaneously so it really doesn't matter if you use output 1 or output 2. Or, you can use this as your virtual "y cord" if you are doing analog speakers.
8) If you are using speakers with digital inputs, like me, use (or add) one more route. Route REW's out1 to playback 5 (which in my interface is SPDIF out Left). Or to playback 6 (which is SPDIF out Right). In this way, Jack is your switcher which selects either left or right loudspeaker. You can be a couch potato, not move a single cable or human being during the measurement. To make things "foolproof", save a pair of Jack Studio setup documents, one for left speaker and one for right and load them to switch loudspeakers. This makes sure your nimble mouse fingers won't accidentally select the wrong patch once you have got things working.
Attached is a picture of a jack route, showing REW routed simultaneously to playback 1 and playback 5 in the Motu.
9) Have fun! Yes. Did I say "Have fun"! This procedure works so well that I am having fun. I must say that the Soundflower/Line Input thing gave me a headache, but Jack just makes me feel real good and real powerful.
Best wishes,
Bob Katz
2/22/14
Noto bene:
a) With this method, Soundflower and LineIn are NOT NEEDED. Aggregate Devices are NOT NEEDED. MULTIPLE OUTPUT DEVICES ARE NOT NEEDED. In fact, Linein currently is broken on OSX 10.9 Mavericks, it crashes during the install. And I also discovered that Soundflower will not feed any sound to the Motu SPDIF output although it can route to it on screen, no sound makes it to the MOTU SPDIF output. Since I am using SPDIF output AND I want to have analog loopback I have to use this method.
b) You may be able to pull this off with Soundflower alone and not need JackOSX if you are doing an analog feed to loudspeakers only, but I have not tested it. In that case you would use an analog loopback cable from the other analog channel into a combo mike/line input. Or, if you are adventurous, make a 60 dB attenuator, but I won't go there
And assign REW's input to the Motu interface so you don't need LineIn.
c) Initially I tried to use JackRouter to route the input signals to REW. But for some reason, REW or Java or something parallels the left and right inputs to REW so that both the In and Ref inputs get the same signal. This could be a bug in Java or a bug in REW or something else. Fortunately, if you can use the first two inputs of your interface for in and ref then you do not have to use JackRouter for the input routing. UPDATE: I tried this with my Metric Halo ULN-8 interface (firewire), which has full internal routing facilities and so we would not need JackRouter, and got the same behavior. No matter what channel I routed the mike and loopback to, REW continues to receive information on BOTH the input and loopback. So it appears that REW's input, when set to default device, will not work properly for loopback purposes with routing software.
