| REW Forum Logorithmic graphs REWDiscuss Logorithmic graphs REW in the Subwoofer Equalization | Calibration forum; Logorithmic graphs REW Hi all,
Going to try and use REW for the first time. One question though, how do I set the ... |
| | #1 (Link) | |||
| Logorithmic graphs REW Hi all, Going to try and use REW for the first time. One question though, how do I set the graphs to a logorithmic plot? I see a logorithmic sweep, is that what everyone is referring to? Thanks! | |||
| | #2 (Link) | |||
| Re: Logorithmic graphs REW Hi there Shawn, You can do it through the drop down menu labeled "Graph" and then there will be an option for "Frequency Axis Log/Linear." That will toggle between the two. Using the hotkey combination Ctrl-Shift-A will also toggle between the two. Good luck! -- Otto | |||
| | #3 (Link) | |||
| Re: Logorithmic graphs REW Or you can click the "Freq Axis" button on the toolbar http://www.hometheatershack.com/room...panel.html#top | |||
| | #6 (Link) | |||
| Re: Logorithmic graphs REW I'm sure this is going to end up being a dumb question but...how do can you tell which mode you are in? I can switch back and forth but I don't see any indicator for which mode I am in. I can see an obvious difference but I don't know which is linear and which is logarithmic. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| ETC Graphs | Bob_99 | Home Audio Acoustics | 8 | 11-05-07 03:42 PM |
| First REW graphs - Advice pls | Ninj | REW Forum | 21 | 04-20-07 01:49 AM |
| Latest REW graphs of my budget sub... | blazerman | REW Forum | 3 | 02-14-07 01:36 PM |
| More first REW graphs - thoughts? | avnetguy | REW Forum | 7 | 07-20-06 08:58 PM |
