| REW Forum First graph. What do you guys make of this?!Discuss First graph. What do you guys make of this?! in the Equalization | Calibration forum; First graph. What do you guys make of this?! Hello, I am pretty new to REW. But after a day of good reading, I have gotten a pretty good ... |
Views: 612 - Replies: 5
| First graph. What do you guys make of this?! Hello, I am pretty new to REW. But after a day of good reading, I have gotten a pretty good idea on things. Below are my measurements for left and right respectively (with filters included). ![]() ![]() What's going on there around 200hz??! | ||||
| | #2 | |||||
| Re: First graph. What do you guys make of this?! Quote:
The range that filter corrections are effective is much larger at low frequencies. At frequencies above subwoofer range, the effective listening area improvement of a corrective filter is quite tiny (smaller as the frequency increases) and so is of little value. Filters at these frequencies could easily make things worse. Narrow peaks or dips would not be audible, nor would they respond to equalization over any useful listening area. brucek | |||||
| | #3 | ||||
| Re: First graph. What do you guys make of this?! I am going to use software convolver with the filter IR (PC as source). I wonder if that is appropriate. And yes, I am using no subwoofer. So these are measurements of my main. I guess my question is really about what does the big dips tell about my room accoustic or speaker placement, whether it can be remedied with EQing or not. | ||||
| | #4 | |||||
Measure at different locations, and the dips and peaks for the mains frequencies, and the result will be completely different. brucek | |||||
| | #5 | ||||||
That said, I’m not sure how “appropriate” or a PC-based EQ is useful in a home theater. I gather you’d be using the PC’s DVD drive and a 5-1 soundcard fed directly to amplifiers or powered speakers? Quote:
Regards, Wayne | ||||||
| | #6 | ||||
| Re: First graph. What do you guys make of this?! Thanks for all the replies. My speakers are actually rated with FR from 45hz to 22khz. And stupid me, I have adjusted the curve with full-range speaker option the whole time. After choosing "bass limited" option with cutoff at 40hz, there are actually at least four peaks found below 50hz range. Hope this means that the IR will be helpful in my case. Also, I am only using this for my stereo setup, fed from my PC through toslink to an external DAC. | ||||
